how many qTs of oil do our C32 need?
Old Jan 24, 2003 | 02:44 AM
SiLvaC32's Avatar
C32
so... how many? 6? or more?
Jerry
Old Jan 24, 2003 | 12:49 PM
rrf's Avatar
rrf
8.5 if empty
If you drain from the bottom and have a dry filter it will be very close to 8.5.
Run the car for a few minutes to warm it up, then stop and wait a few minutes. Check the level with "dyno mode". It will give you some number like "7.5 Quarts", repeat if you are skeptical or it is unusual. (This electronic reading is your "dipstick" so you will refill to that level)
Drain your oil and then refill with a quantity LESS THAN 8.5 , say 8.0. Recheck via dyno mode. FILL WITH about half of what it suggests you might need to get back to the original basepoint ABOVE. Drive the car and then recheck.
The reason you use 1/2 of the difference it indicates, is it is a lot easier to add than remove when you overshoot. You will also see the dyno sensor reading is "touchy". Driving around to coat the engine has a large effect on the reading also.
Old Jan 24, 2003 | 02:31 PM
dondi's Avatar
2003 C32 AMG
It does take 8.5 quarts of oil (mobil 1). I just got my oil changed and thats how much they out in.
Old Jan 24, 2003 | 03:55 PM
SiLvaC32's Avatar
C32
whatz dyno mode?
Old Jan 24, 2003 | 04:54 PM
rrf's Avatar
rrf
Oil reading in Dyno mode
To reach the Oil Level display in Diagnostic mode
1. To start, the key must be removed from the ignition.
2. Insert the key and turn to position 1.
3. Immediately press and hold the trip odometer reset button until the instrument cluster beeps. There is no visual message, only an audio beep. Be patient, this takes around 40 seconds.
4. Press the (right, slightly lower) menu button (it looks like two sheets of paper, the one with the writing in the background behind the blank one)
5. Turn Key to position 2 to get the Oil Reading and Engine Number Engine is
AMG W112
Old Jan 24, 2003 | 10:45 PM
SiLvaC32's Avatar
C32
woah... that is so cool! ehh... what kind of oil does everyone use btw??
Jerry
Old Jan 25, 2003 | 07:58 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Mobil1...the brand AMG recommand and I could care less to find another brand of oil.
Old Jan 25, 2003 | 08:00 PM
E430tuner's Avatar
MetroCard
8 qts is fine.....8.5 is a bit too much
Old Jan 25, 2003 | 11:17 PM
Stevo's Avatar
E320
STEVO'S POST REMOVED BY MBWORLD STAFF: THIS IS HIS FIRST AND ONLY WARNING.
Old Jan 25, 2003 | 11:53 PM
SiLvaC32's Avatar
C32
did he offend u in someway?? i thought he just said 8 qTs?!?!
Jerry
Old Jan 26, 2003 | 06:51 PM
jswedberg's Avatar
C32 AMG
And what does the picture of old knives and guns have to do with oil levels?
Old Jan 28, 2003 | 03:09 AM
Stevo's Avatar
E320
Old Jan 28, 2003 | 01:45 PM
SiLvaC32's Avatar
C32
ewww
