Tranny fluid change on a C55?
1. drop the pan
2. drain fluid
3. change filter
4. put a new filter in
5. put the pan back in
6. make sure to seal the pan (no leaks)
7. fll up with fluid (its gonna take about 3 quarts)
8. check you fluid level witht the MB dip stick
9. good to go
Also, is there a gasket on the pan, or do you just use, say, black RTV?
Bill
1. drop the pan
2. drain fluid
3. change filter
9. good to go
LOL
I do recommend changing it, when i changed mine at 85k, the fluid was black.
