Help - car troubles!!
Old Mar 7, 2009 | 11:46 AM
AMG_Freak's Avatar
C32 AMG
I finally decided it was time to take my car for a spin after 3 weeks of just sitting there looking pretty in the parking lot.
I opened the door with the remote key, put the key in the ignition... and that's about as far as I got. Key wouldn't turn, felt like it was locked...
Figured my battery had gone dead and needed to be charged. I manually locked all the doors.
This morning I went out to try to jump my car and I can't even get in. The doors won't respond when I try to unlock the car. I never had problems with my doors not unlocking so now I'm even more worried...
Anyone know what I need to do?
Old Mar 7, 2009 | 11:57 AM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
your battery is completely dead. It was probably from the seat controller going bad.
unlock with valet key, charge it up and go for a ride.
Old Mar 7, 2009 | 12:19 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
And make sure you charge the battery completely prior to going out or you will over tax the alternator and possibly cause premature failure of that too.
Old Mar 7, 2009 | 12:22 PM
1qikctr's Avatar
Merc power
Old Mar 7, 2009 | 01:00 PM
AMG_Freak's Avatar
C32 AMG
Thanks guys... I got it.
Old Mar 8, 2009 | 07:20 PM
PeterTheFish's Avatar
02 C32 AMG
Don't forget to unplug the seats...
Otherwise you're likely to have many happy repeats...
Old Mar 9, 2009 | 04:16 AM
AMG_Freak's Avatar
C32 AMG
Unplug the seats?
Never heard of such a thing. Is this a known issue?? It could explain why my battery went dead in the past. This is just my weekend or every now and then car.
What's the procedure?
Anyone having any problems with their factory CD changer? For some reason it doesn't see the CD's in the magazine. Sounds like its looking for them but ends up stating magazine empty. Weird...
Old Mar 9, 2009 | 12:12 PM
eddie1628's Avatar
C32
unplug those cables under the seats then recharge the battary
Old Mar 9, 2009 | 12:47 PM
2002 C32, 2012 S550
See this thread for all you need to know.
https://mbworld.org/forums/c32-amg-c55-amg-w203/201140-one-stop-search-newbies-start-here-created-7-10-07-a.html
Old Mar 13, 2009 | 07:41 PM
AMG_Freak's Avatar
C32 AMG
Originally Posted by Gramma_Benz
Haha... you just referred me to the encyclopedia.
Thanks for the reference tho!
Old Mar 16, 2009 | 08:40 AM
02 C32 AMG
More specifically...
See https://mbworld.org/forums/c32-amg-c...tible-c32.html.
Basically, the seat control modules have a feature that keeps them on even when the car engine is off, so that one can adjust seats without putting the key in the ignition. Unforunately, the modules tend to fail fairly regularly, the result being a current drain large enough to drain your battery overnight (although not every night).
The quick fix is to unplug the seat control module. If you reach under the front of each seat you should be able to locate 3 electrical plugs - removing these will disable your power seats, but save your battery and alternator (often secondary casualties of the seat control module malfunction).
Old Mar 16, 2009 | 09:18 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
here's the cheap $20 fix for it.
https://mbworld.org/forums/showthrea...55#post3068555
