P0300/ P0304
P0300 multiple/random missfire
P0304 Cylinder 4 Missfire
I don't know where to start? Car has close to 150K on the dash, replaced the wires and plugs less then 30K miles ago (the ones from letmotorsports)
I also have to replace the IC pump (again) not sure if that has anything to do with it.
Thanks!
Thanks!
Based off a similar issue I had the multiple / random misfire is usually caused by one cylinder misfiring...well my issue was cylinder 6 gap was off from rest...I bought new plugs and thanks to AMG JERRY got them installed and gapped properly and issue is no longer non existant. I would check that the gapping on all are identical also that the wires are making firm contact and lastly the coil packs make sure there is no currosion on them or underneath them if so clean all contacts properly. GL
first thing to do...see if its wires or cold packs
Today, about to go home from work I start the car and see "Battery/Alternator low, visit workshop!" flashing in red. I left the car in the parking lot since I was not sure if I would make it home before the car would stall. I am about to order the Valeo Alternator from alleuropeanautoparts for $290. Is this a DIY job? Has anyone replaced one before?
Btw, I did not swap the spark plugs yet posted in original threat, probably will replace them when I do the alternator.
You don't necessarily need to swap the alternator; a bearing in the pulley system might be busted.
Turn on the car and take a look at your belt. If you can get someone to rev the car while looking at it you might see some wobbling.
GL
I still have the vibrating issue, replaced two spark plugs at cylinder 4 and no difference (although the plugs looked pretty bad) I guess next step is to replace the wires (anyone know if LETMOTORSPORTS still sells them? I don't see them on their website) if that does not work, I'll go back to OEM I guess
