Single Xenon bulb replacement?
Can't be too tough? One of mine is pinking out and I can't shell out right now for DEPOs and a HID kit (... and fog light replacements and LED parking lights and...)
Also, how can I check equipment codes to see if I have D2R or D2S bulbs?
TIA
TIA
Buy after market bulbs from like a Carlab if they are still around go with 8k brightness it works great. As for the type take out the faulty one and read what it says...not a hard job to do it is an easy DIY.
Does it actually say on the bulbs? Don't have the car with me tonight, otherwise I would have checked. Just the same as a halogen bulb replacement but with a diff bulb, right, no crazy wiring?
I can't seem to find Carlab (Carlabs?) anymore, but http://www.intensehid.com/d2c.html seems like a decent replacement, and they've got some pretty stellar ratings on all the online store ranking sites. $50 for a pair of 10kKs is awesome too ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
I ordered some 10Ks already, but I'll PM ya if they're not bright enough, or if the color sucks through the stupid, stupid, STUPID frosted lenses /grumble
2008 A8L, 2002 996TT X50, 2009 X5
Well, the stockers are 8k, right? They are WAY more than bright enough, and I would imagine that aftermarket ones are even brighter than OEM, matching color for color. I'm just a fan of the deep blue/purplish color, TBH, and I'll be upgrading my fogs soon anyway, so...
I've stuck with OEM, even when changing bulbs, because you won't/can't really get better from a performance standpoint. YMMV.
Stock is 4100-4300ish, IIRC. That's a fairly "white" light output, and around the highest lumens you'll get. Some don't mind the compromise going to a 6k bulb (Philips Ultinon used to be mentioned quite a bit) for a bit "bluer" light, at the expense of some lumens. From there, it starts to drop off fairly quickly... 8k IMHO is borderline, and anything over 10k is basically worthless (think "blacklight for headlights").
03 g35 coupe...........02 c32 Sold
So people know in the future...the kelvin rating is just to show what color it is, not the amount light it gives off. 4300k is like whitish yellow and 8k is basically blue.
if your have the frost lens oem bixenons you need d2r bulbs. If you have the clean lens oem projector bixenons then you need d2s. If you only need it temporily, then you can buy a set of chinese hid bulbs on ebay for $25. Oem is 4300k like other have said. If you want more of a pure white you can go with 5k or 6k. Do not go higher then 6k or you lose too much light.
I believe your can get the oem philip bulbs for $100 on ebay
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
I'm starting to think I'm going to regret buying 10K bulbs now
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
At least the bulb that *was* pink is back to a really deep blue and only flickering a tiny bit... Guess I have to stop dishing the Breast Cancer support pickup lines, though >_>
W203 C32 AMG, W124 E300D
I Had 8K on my yamaha R6 (got the kit free from a friend) and it was worse then the stock halogens. Needless to say I swapped the kit for a 5K.
The OEM Osram bulbs i have are labeled 4100K. So if you dont like the 10K's you bought (which I suspect you wont) ill let them go for cheap.
Or on AutohausAZ for ~$95 a pop ![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
I'm starting to think I'm going to regret buying 10K bulbs now![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
http://cgi.ebay.com/ebaymotors/2-NEW...spagenameZWDVW
OEM is always good, but $40 more for a brand name? Ofc, charging more for OEM parts just b/c they're Mercedes-Benz is kinda what MB is all about ;-)
10k have LESS output. Stockers are 4300k.
10k are really ricer, and unsafe.
Thanks for the link, but for $50 shipped at the HID site I linked further up, you can get any color in the Kelvin rainbow for D2R/D2S, so... >_>
if your gonna get the cheap chinese bulbs i suggest you keep a back up set.
Keep in mind that I'll more than likely be replacing these with OEM Bi-X or DEPO + a quality HID kit in about three weeks, so I'll probably end up stuck with whatever bulbs I buy now anyway. Before/after pics to come when they show up, however, just to laugh at how ricey they might be
