Traction Gains
Are there any appreciable traction gains when one moves from the 7.5/8.5 staggered OEM wheel setup to 8.5/9.5 staggered that most forum members run?
I'm assuming yes, since you're increasing your contact patch--but I don't know if the benefit is noticable or not.
If I did buy new wheels, I'd probably stay with 18s.
Thanks in advance for the info.
How's it going? Bolded section above is a common misconception. Contact patch does not increase as you alter wheel width, nor does it increase if you mount wider tires. You do wind up reshaping the contact patch, however (i.e. wider, but shorter).
Regarding the tires, you're right--that does seem a little counterintuative.
So riddle me this. If someone was to put a widebody kit on their car and were able to get 315s on the rear wheels--they would have the same amount of rubber on the ground as with 265s?
Yes, if the same model tire, same psi, same load on the tire (i.e. vehicle weight), the surface area of rubber on the ground should be approximately the same. The contact patch rectangle gets wider, but decreases in length. That's not to say that "wider" isn't important - all things equal, it should corner, brake, and wear better (and probably accellerate better, if wheel spin is an issue with the narrower size).
TemjinX2's right, you'd probably notice a bigger difference going to an overall stickier tire. A plus-zero wheel fitment can improve handling if it's a wider wheel and/or lighter wheel - you're just not necessarily putting "more rubber to the ground" if that makes sense...
The other thing is that traction is not only from static friction, or hysteresis. There is also an adhesive friction which comes into play more when the tires heat up. So a greater contact patch, although there will be less ground pressure, is still beneficial.
Of coures, the most effective way to increase traction is to change tire compounds, but then you sacrafice tire life.
I'm going to answer this in a very straightforward way. Moving up an inch in wheel width is more for looks than traction(even if tire width is increased proportionately). This has pros and cons though...
Pros... Cooler look. Slightly larger contact patch(not much of a pro)
Cons... Increased wheel and tire weights. Greater rolling resistance. Decreased RWHP(if larger wheels are used).
If it's traction you're going after, you're looking down the wrong path. Either switch to a softer compound tire, or increase your tire DIAMETER instead of width. Sidewall height is where traction comes from, not width.
HTH.
