code3 heat exchanger...
mercedes c32
Hey anyone out there let me in on what the heat exchanger is all about... i tried looking everywhere.... but cant seem to find out the info i am lookin for
1 Post
03 C32 gone, 06 CLS55, 16 Tesla X
Look at Code3's site or EuroChagered's site to have an idea what it looks like.
edit: I am guessing your next question will be what the johnson pump is for jk
On our cars, it is very common, almost guaranteed that your Intercooler pump will go bad which feeds the Heat exchanger. Many people tend to buy an aftermarket one made by Johnson that tends to cost less and pump out more coolant, again making an effort to make your intake charge cooler.
Code3 and LET both make aftermarket Heat Exchangers larger than the stock/OEM one. Which one is better is a toss up, but LET has a reputation for first class service and no BS. Code3's record as of late has been less than stellar.
If you have no mods so far, I would recommend either an intake or pulley first.
http://letmotorsports.com/
http://eurocharged.com/
code3performance.com
It's not technically the same as an intercooler, but for the C32's achieves much of the same effect. It helps cool down your Air Intake Temperatures(IAT's) which in turn will give you more power, more consistent power(when your engine heats up) and gain efficiency.
mercedes c32
Code3 heat exchanger = the product that exchanges the heat to help reducing the IAT manufactured by Code3. Make sense? jk...jk
2008 A8L, 2002 996TT X50, 2009 X5
Best of luck - search for Splinter's DIY thread on the heat-exchanger R&R job, it's top notch.
mercedes c32
Hey.... appreciate the good advice.... will do
Super Moderator
garykit- it’s on another forum…http://mymbonline.com/forum/viewtopic.php?t=6430
SPONSOR
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
ya, they are pretty much the same thing....only issue seems to be it might take 2 months to get the code3 one
mercedes c32
Thank you, c32AMG-DTM.
Ok great, i ll check it out.... thanks
mercedes c32
mercedes c32
Thanks...ok might hang on for the code 3 H.E...... Did ya fit it yourself? wanna try it myself.... kinda scared of getting air in the system... and worse still gettin to it bumper off etc.... just sick of gettin ripped off in the garage...uk= shocking labour costs.... was it a nightmare to do?... Thanks
mercedes c32
03 g35 coupe...........02 c32 Sold
mercedes c32
Ok.... thanks... i already changed the i.c pump about year back... johnson.. will follow his d.i.y... all good. thanks...
