Front Bumper Gap Adjustment - Help!
Old Apr 15, 2009 | 11:58 PM
Ultraman's Avatar
2019 E450 Coupe 4Matic; 2018 Audi Q5; 2019 Toyota Corolla Hatchback
Could someone tell me how could I adjust the front bumper gap as shown in the picture:
Is it an easy DIY?
Thanks.
Old Apr 16, 2009 | 12:31 PM
pshek's Avatar
2003 C-Class Sportcoupe
That's easy to fix. Just loosen the bolts holding the fender at the top and pull the fender out away from the headlight. There should be a C shaped plastic clip holding the fender to the bumper. If the clip is not it place correctly, there will be a gap at the front. Just make sure the clip is there holding the fender against the bumper.
Old Apr 16, 2009 | 10:59 PM
Ultraman's Avatar
Are you saying removing the push pins behind fender? Is this the same procedures asremoving the plastic fender for replacing the fog bulbs?
I read the other threads regarding replacing the front bumper, there is a long clip tightened by a torx screw (or whatever screw). If I removed this c-clip, will the left hand side bumper lose freely in order for me to push in or out for the bumper alignment?
If this is the case, I will try this weekend.
Thanks.
Old Mar 13, 2010 | 02:24 AM
dacls63amg's Avatar
2008 CLS63 AMG
I have the same issue il be fixing mine tomorrow.
Old Jul 12, 2010 | 09:27 PM
gtr886's Avatar
E63 W211 08, C32 W203 02
Any updates on this?
Old Jul 12, 2010 | 11:23 PM
Ultraman's Avatar
Hey guys,
It works. There is a metal clip behind the gap. All you need is turn the wheel either all the way to the left of right (depends which side is the bumper gap). Remove those plastic push pins and bolts from the fender liners so that you can pull the fender liner out and have a flash light to find out where is the metal clip. The metal clip is fastened with a metal screw. Unlock this screw so that loosen that metal clip.
After you loosened the metal clip, now you can adjust the bumper gap. Once, it is aligned, push the metal clip to lock it in position and secure with the metal screw. Double check the gap again before you re-intall plastic liner and plastic push pins and bolts.
Hope this help!
Old Apr 24, 2021 | 07:54 AM
Handalw211e55's Avatar
E55 AMG
Fixed ! https://youtu.be/caHLFVIqND4
Is it an easy DIY?
Thanks.
Fixed.
Old Apr 14, 2023 | 08:10 AM
fanfan's Avatar
2007 CLK550, 2014 ML350
Thumbs up
Hey Boss,
You did a great job. Props to you. Looks very neat.
Old Apr 14, 2023 | 08:11 AM
E55 AMG
Originally Posted by fanfan
Hey Boss,
Thanks! Happy to help! 👍👍
