Question for all 185 pulley and tune user?
Old May 7, 2009 | 03:00 PM
Robert AMG's Avatar
Cls63 & C32
What are the spark plugs that you are running with guys?? for those who are running lean at top (CLKCLK, TemjinX2, razormb)
Thanks.
Old May 7, 2009 | 03:36 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
Thanks.
I'm running IK20's
Old May 7, 2009 | 05:07 PM
CLKCLK's Avatar
03 C32 gone, 06 CLS55, 16 Tesla X
Thanks.
Stock when dynoed.
I current have NGK Iridium IX Spark Plugs one step colder than stock. But have not yet re-dynoed it. (It does not make sense to re-dyno for new plugs). I also have new fuel filter. Well, let see what it makes on May 16th. I think good spark plugs would make you run leaner. Good fuel filter should make you run richer.
Old May 7, 2009 | 05:50 PM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
Originally Posted by CLKCLK
Stock when dynoed.
Hmmm... not sure that different plugs or fuel filter will materially affect your AFR. Seems that the 185mm crank pulley + tune overtaxes the stock fuel system at high load, high rpm - this has been pretty well documented at this point.
Adding mods that help lower boost (i.e. addressing post-blower restrictions) has been shown to help this, as has Bulldogger's mod to add more fuel pressure to his SRT-6 (bear in mind, he was running as lean as 15:1 at high rpm on the dyno, and he's running the 181mm crank pulley). I have a feeling that we'll see many 181's and 185's follow in his footsteps, in order to run safer AFR's at high rpm.
Old May 7, 2009 | 06:13 PM
Robert AMG's Avatar
Cls63 & C32
yes if our stock fuel system as it appears with the 185 pulley is overtaxes, so we must upgrade it to gain the maximum power from this setup, this by upgrading the fuel pump or the injectors not by lowering the boost.
I am just thinking if we are running with stock heat range plugs like oem and ik20, this will affect our high top rpm AFR???
Old May 7, 2009 | 06:20 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
+1 i agree.
Old May 7, 2009 | 06:21 PM
  #32
TemjinX2's Avatar
tell you the truth, i hope the c55 works because i would rather just replace the fuel pump since i need to do it anyways rather then use fuel booster.
Old May 7, 2009 | 06:32 PM
  #33
CLKCLK's Avatar
... by upgrading the fuel pump
I believe LET had tried this but unsuccessfully since there is only that much flow (gas) inside the pipe as the max our pump can push. We need a better pump. But which pump? No one has the answer yet.
...lowering the boost...
I believe he means by increasing the diagonal of the air flow like the modified intake manifold or Needwing intake many fold, or headers, not by running smaller pulleys
I don't think so either. I've said to see if it makes any different. However, a clogged fuel filter, or bad/weak fuel pump may reduce a lot of flow to the injectors. This will be soon answered.
It's great if you can do a research on this. Call dealer to ask if they can fit. Please update us.
Old May 7, 2009 | 06:36 PM
  #34
Robert AMG's Avatar
Cls63 & C32
but the main issue we want to know where is the problem before we pay more money, is it with the tune, with the pump, plugs???? we are all waiting May 16.
Old May 7, 2009 | 06:51 PM
  #35
Robert AMG's Avatar
Cls63 & C32
Tomorow i'll do a test for the pump:
i'll put something like gate valve ( i don't know how is called, sorry for my english) in the return pipe at the fuel filter, like this the system will overflow and i'll see the AFR.
BTW stock pump c32 has a pressure of 4 bars (58-60 psi), today i have test it.
Old May 7, 2009 | 11:46 PM
  #36
razormb's Avatar
CLA
Originally Posted by Gramma_Benz
I'm running IK20's
Same here.. did you guys gap yours?
Old May 8, 2009 | 11:11 AM
  #37
CLKCLK's Avatar
Gap will help the miss firing issue, but will not help on A/F issue
Old May 8, 2009 | 11:23 AM
  #38
2002 C32, 2012 S550
I didn't, left it at manufacturers OEM setting. I installed mine prior to adding boost. But from what I've researched, it seems that gapping at .035 is best?
I think OEM is .039 for the IK20's.
Anyone else with any experience? Should I re-gap my plugs prior to getting Dyno tuned by LET?
Thanks in Advance!
Old May 8, 2009 | 04:07 PM
  #39
Newzchspy's Avatar
PLAID
Originally Posted by c32used
I have yet to dyno since 185 install but I can say she runs great
Whats your best QTR so far Vic???
Old May 9, 2009 | 07:22 AM
  #40
Robert AMG's Avatar
Cls63 & C32
I did the test today, no change in the AFR.
The pressure of the fuel system was 4 bars, i closed the valve that I installed on the return pipe to I got 4.5 bars then to 5 bars, the AFR still the same, lean at high rpm.
So our problem is not in the pump.
Old May 9, 2009 | 09:34 AM
  #41
c32AMG-DTM's Avatar
But the increased fuel system pressure lowers the duty cycle on the injectors, correct? Your tune can subsequently be revised adding more fuel back in - at least, this is my fairly rudimentary understanding of the tuning side of it.
Old May 9, 2009 | 10:03 AM
  #42
2002 C32, 2012 S550
Cool, thanks for taking the time and testing that for all of us!
Old May 9, 2009 | 10:41 AM
  #43
ImportLabSRT's Avatar
2006 E55 2005 Crossfire SRT-6
I have a question for the people that have experienced going lean.... is it only on a dyno that you go lean? I have a lot of mods on my car (see sig) and when "street tuning in Mexico" I never go leaner than 12.8:1... and I have taken the car up to 140mph in 4th gear and hit 21psi (low boost due to manifolds but a lot more gm's/sec of airflow). And I have zero fuel mods.
Old May 9, 2009 | 11:10 AM
  #44
CLKCLK's Avatar
First it hick up on the freeway at early morning/WOT around 70mph-80mph like a tick.
After retune, the problem is gone now, but they show as lean as each other on the dyno. My retune was a bit improved between 5200rpm-5500rpm, but still high at 13.x-14.x and after that it all sky rock the same
Old May 9, 2009 | 12:52 PM
  #45
Robert AMG's Avatar
Cls63 & C32
I have the LM-1 wideband installed before cats, i am running lean on street at 3, 4 and 5 gear.
First tune i didn't have yet the LM-1 but the car was losing power at high rpm,second tune: AFR= 15 after 5200, after my third tune AFR= 15 after 5500.
BTW E55K have a pressure fuel system of 6 bars, today i have test it on my friend car.
Old May 9, 2009 | 02:03 PM
  #46
2002 C32, 2012 S550
I have the regular "mail in" 185 tune and on the street when WOT in 3rd gear, I get a sputtering just past 5K RPM's and loss of power. I had my mechanic go for a ride with me and hook up his diagnostic scan tool. It showed lean conditions and finally threw a CEL.(I believe it was misfires).
I was going to send it back to Jerry for a re-tune, but decided just to wait until the Northern CA Custom Dyno tuning day which was a month away at the time. So I've just been taking it easy until then.
Old May 10, 2009 | 02:52 PM
  #47
ali saklaoui's Avatar
C32AMG.335 e92 fbo.protomotive996 gt2
Hello, i am thinking to install an extra injector,that will be activated by an adjustable boost switch.
Old May 10, 2009 | 07:05 PM
  #48
Robert AMG's Avatar
Cls63 & C32
That's what I was thinking, to install it at the intake manifold but waiting 16/5 to see if this issue can be solved by tune, if not we will try it.
Old May 10, 2009 | 07:24 PM
  #49
Bulldogger's Avatar
SRT6
What you need to do is find the stock specs on the factory pump. The SRT6 one flowed 60 g/p/h at 45psi and 45 g/p/h at 73psi. The SL55 AMG pump flows 95 g/p/h at 45 psi and 75 g/p/h at 75psi the flow is greater but very close to operating psi.
What you guys need to do is look for an intank fuel pump that was used in some year AMG car. If the SL65 has one then I would look into it. Look for any Mercedes car with factory hp of 450+ that uses an intank pump.
As far as why some of you guys and some SRT6 guys run lean and some don't all has to do with the mods. If your intake is a little on the restricted side you won't run lean. If your intake has no restriction but your exhaust is a little restrictive you won't run lean. When you combine both, a near zero restriction on intake and exhaust then you have the magic comdo for running lean. My intake is SL55 with high flow filters and modded intake plenums. My exhaust is primary cats and straight through dual pipes with Kooks racing mufflers. If you hold up my exhaust you can look through it like a telescope. Hope this helps.
If you find the factory pump is up to the task then the next choice would be larger injectors. I would like to see the pump spec first, before going the injector route.
Old May 10, 2009 | 07:47 PM
  #50
jturkel's Avatar
02 C32 AMG
dyno tune ftw!
