Dyno results after 1000 miles
Mercedes C32
Looks like with Just Evosports' Pully system you are already hitting 314 rwh. Can you imaging if you had the Renntech chip or H&S chip installed in the car? You'll be in the 335 rwh range. With 17s your be in the 340s. That's way more than what Renntech can offer and with much cheaper price.
Good Job Evosports.
Peter, we should upgrade our Chip
Good Job Evosports.
Peter, your peak TQs are:
Stock: 280 ft.lbs.
Stock 19s: 274 ft.lbs.
19s ODPS: 305 ft.lbs.
We are working with a couple companies in Europe on software. I will post the results as soon as we get them.
Further R&D note. The headers are done and we are testing them on my car. I will post more data and pictures next week.
Stock: 280 ft.lbs.
C32 AMG
Originally posted by E55JAY
Do the 19's rob power because of weight, diameter, or both?
Porsche Turbo Stage 4, Cayenne S ... gone C43, C32, ML55 & Ducati 999.
vadim, I am really exited with the Evosports' Pully system, as well as headers.
On Monday I will go to the dealer to check the alternative reservoir that I am researching to install in my car, in front to the ABS/ESP box, candidates are the SLK230 and the '03 S600. If am successful, I will let you know.
Getting that I will order your Pully system for sure.
Further, due to the altitude I have no intention to change my stock wheels.
Bye
Pierre32///AMG
Bye
Pierre32///AMG
C32
its the size guys (i think)... the weight shouldn't be that much different from a stock 17 AMG wheel to a 19 BBS LM. the BBS wheel doesn't even weight that much.
Jerry
Jerry
pc527, it's really impressive results !!
Do you check the coolant temperature before vs after the Evosport ODPS upgrade ?
p.s
Assume you know the diagnosis mode in the A/C panel.
p.s
2005 B6 S4
p.s
p.s
shine, i do keep a close look at the temperature and it's about the same. maybe just a lil' bit higher, but not by much.
peter
