Secondary Cat Delete Question, C32
Old 05-15-2009, 05:26 PM
jturkel's Avatar
02 C32 AMG
When deleting the secondary cats and them with pipes (i want to use SS), what diameters pipe should I replace it with? i know my resonator was replaced with a 3'. Also, what length in piping would I need to replace them both?
Thanks,
Josh
Old 05-16-2009, 12:42 AM
jturkel's Avatar
02 C32 AMG
any ideas?
Old 05-16-2009, 04:36 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
i think the c32 piping was 2.75''. Wouldnt you lose too much backpressure with 3'' piping?
Old 05-16-2009, 07:07 AM
jturkel's Avatar
02 C32 AMG
from what i remember from what Vadim has said in the past, backpressure isnt an issue for the c32s.
Old 05-16-2009, 09:15 AM
rockjock's Avatar
I DON'T COME HERE ANYMORE
I wouldnt be too concerned with the BP on the 32's either-2.75" is correct-as for length-ummmm.....is a shop doing it/weld in, or are you flanging everything for easy swap/emissions inspection?
Old 05-16-2009, 11:00 AM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
I just completed this mod a month ago. I used 2 1/2" SS 304 pipe into the stock Y-pipe. Then more of the same pipe into 2 3/4" Supersprint exhaust.
I got the pipes from these guys. Super fast shipping.
http://www.verociousmotorsports.com/...s-Steel-Tubing
I'm also confirming that that at the resonator location, the piping is 2 3/4".
Old 05-16-2009, 03:14 PM
jturkel's Avatar
02 C32 AMG
yes a shop will do it. it will pass emissions without secondaries, and they havent done a visual inspection on my car in the past, so i'm not worried about that.
ok. so if MY resonator was replaced with 3", do I need 2 1/2" to 3" so I can connect to the Y-pipe up front (2 1/2") and the pipe replacing the resonator (3") in back?
Old 05-16-2009, 03:42 PM
Lenin's Avatar
Sounds like it. I recommend you talk to the people that will be doing the job and let them measure everything, figure out how they can connect everything and then tell you what parts and the sizes you will need. This is not engine work where you need to be exact. There are a few different ways to connect these pipes.
Old 05-18-2009, 06:35 AM
jturkel's Avatar
02 C32 AMG
hmm ok
Old 05-18-2009, 09:42 AM
SilverBulletAMG's Avatar
C32 AMG
2.5" is what I used. I wouldn't go more than 2.75" personally.
Old 05-18-2009, 12:07 PM
willc55's Avatar
2009 Mini Cooper Clubman S
Out of curiousity, how much, on average, does an exhaust shop charge to chop the secondary cats? I'm thinking about doing this and a res delete at the same time, and wanted to know what I should be paying.
Old 05-18-2009, 05:16 PM
jturkel's Avatar
02 C32 AMG
well i think i have to have 3" somewhere because that is what i replaced my resonator with. i think the pipe going into the secondaries is 2 1/2" which is why i think i need to have a 2 1/2" to 3", no?
my resonator delete cost me 50 in labor and 30 for the pipe (it was a 3" SS pipe that was like 2 or 3 ft long)
Old 05-18-2009, 05:44 PM
rockjock's Avatar
tech. a shop shouldnt be taking the cats out-so they may play dumb if you ask-after hours-depends on the pipe again, but some would give you a "what if" # if it was in the air.
Old 05-18-2009, 06:28 PM
Lenin's Avatar
What I was trying to say earlier is that some shops may put one pipe over the over and then weld it. And other shops may butt one to the other and weld it. Does your pipe that replaced the resonator goes over the pipe that goes to your muffler? From what I recall, the muffler is 2 3/4".
These are secondary cats. What purpose do they serve?
Old 05-19-2009, 08:51 AM
C32 AMG
I guess mine is 2.75" all around, not 2.5" as I previously stated. I started to doubt myself after my previous post and asked the guy that did the work for me.
He said you have several options for joining the 2.75" to 3" pipes and should have no drawbacks from it. Any reason they replaced yours with 3" pipes in the first place?
Old 05-19-2009, 03:50 PM
jturkel's Avatar
02 C32 AMG
b/c i brought them a 3" SS pipe lol. i thought that was the size i needed. and i think someone recommended it to me, though i dont remember for sure
Old 05-19-2009, 06:18 PM
c32used's Avatar
LET C32 2002
Question
How much possible weight savings there? can you post a sound clip once done if not too loud and annoying I will follow suit
Old 05-19-2009, 06:33 PM
jturkel's Avatar
02 C32 AMG
not sure, maybe a couple of lbs...maybe....from what i have read, it is for a slightly louder exhaust sound, which i would like. i will post clips after i get it done.
Old 05-20-2009, 10:49 AM
C32 AMG
I've already done it and have clips on youtube. Pretty sure you had commented on the sound in the past even. The soundclip I posted is old but it does it justice. I can't post a link from work but can tonight if you want.
Old 05-20-2009, 12:35 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
Is this the one?
http://www.youtube.com/watch?v=ROtgZfeDZNs
Old 05-20-2009, 12:53 PM
C32 AMG
Originally Posted by Gramma_Benz
Can't tell from my work PC but it's a 15 second clip (all my camera would record at the time) and was when my car was badged 55 from the previous owner. If that's the one in the link, then that's mine, whic is a pretty old clip....
Old 05-20-2009, 12:55 PM
2002 C32, 2012 S550
Yup, that's the one!
Old 05-20-2009, 12:59 PM
C32 AMG
Cool, thanks for posting that GB.
Old 10-27-2009, 04:49 AM
jturkel's Avatar
02 C32 AMG
ok.....blast from the past....i'm bringing this back.
i think i'm going to do it this time.
anyone think about upgrading the y-pipe? i know supersprint makes one for the C32.
Old 10-27-2009, 07:15 AM
Lenin's Avatar
I considered it since I also have a Supersprint muffler, but given the cost, decided to keep the original y-pipe. Basically, its the Eurocharged header, primary cats, new pipe, original y-pipe, new pipe followed by Superspint muffler.
Quick Reply: Secondary Cat Delete Question, C32
