OEM ic pump vs CM30
Old May 22, 2009 | 01:31 AM
AMG-Driver's Avatar
SL65 R230
Originally Posted by Robert AMG
Upgrading to what??
CM90.
Old May 22, 2009 | 08:10 AM
SilverBulletAMG's Avatar
C32 AMG
Well if anyone wants an OEM pump, I have 2 sitting in a box of spare parts. That is how many spares I kept on hand when running the stock pump and is how little I trusted them.
Old May 22, 2009 | 08:12 AM
C32 AMG
Originally Posted by AMG-Driver
CM90.
You may want to look into that. I have heard issues with too much flow and coolant getting backed up in the IC hurting performance.
Old May 22, 2009 | 12:17 PM
Newzchspy's Avatar
PLAID
Johnson Pumps
+1, I ran into a guy at the Gilmer Rd Shell today. He had an SLK 32 with the "pump issues." I told him doctors make pills for that and he laughed
Anyway, his factory pump went bad and he got a new Johnson 30 and it has worked marvelously (his words) with no problem and no failures for over 50 K miles. Its his daily driver, not a trailer queen. The factory one went out in about 20 K miles. I have not heard of a single problem or failure from the Johnson pumps and some guys on the forum have been running them for years!! Correct me if I am wrong since I am having Jake do mine with a Johnson this next week.
Old May 22, 2009 | 06:32 PM
AMG-Driver's Avatar
SL65 R230
For my system, I will need much flow...
Old May 22, 2009 | 07:14 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
He's gonna do you with a Johnson??
Sorry Glenn, I couldn't resist.
Old May 22, 2009 | 07:21 PM
  #32
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Glenn is used to taking it......
Old May 23, 2009 | 10:17 AM
  #33
Newzchspy's Avatar
PLAID
Yeah, I 'm a big BOY!!!! Just don't disrespect my Stevie Nicks!!
Jake, you'll be seeing me this next week for the mods
Old May 23, 2009 | 10:48 AM
  #34
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
Interesting thread. I'd hazard a guess that most upgrade the HE and change the pump at the same time - muddying the waters for what's truly causing the IAT improvements. My money's *mostly* on the HE... but a well-matched pump could help incrementally I'd think.
That said, I agree with the others that my CM30 has performed reliably over the last year that it's been installed. The stock pump was bad when I bought the car, and it only had 19k miles on it at the time - making me think the IC pump is one of those parts that likes to be run... if it sits for long periods, it'll fail faster I'd bet... more so a problem with the OEM unit, it seems.
Old May 23, 2009 | 01:27 PM
  #35
DarkXerox's Avatar
07 E550, 02 C32, 91 300E
Are there problems with the higher pressure/flow pumps and our crappy intercoolers? E.g. making them more prone to leaking.
Old May 23, 2009 | 01:35 PM
  #36
320 dreamer's Avatar
2003 porsche 996 turbo
fwiw there are many indepth threads on crossfire.org regarding the high flow pumps and ic leaks. to date there isnt a single definative proof that this occurs. the leaks are genarally related to high iats and or high psi from stacked pullies or running the 185 pulley with an improper tune. no one has has had a failure of the i/c and been told it was because of the pump.
Old May 23, 2009 | 05:19 PM
  #37
Robert AMG's Avatar
Cls63 & C32
I want to know the difference in performance about the 2 pumps, the reability is not an issue to me, if the OEM last only 10k its ok, we must know which one flow more then the other and lower the IAT. On the selling websites they mentioned that the CM30 flow 3 times mores the Bosch, from the charts i see the contrary!!
Old May 23, 2009 | 09:14 PM
  #38
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Some members have successfully installed a Davies Craig pump for additional flow.
http://www.daviescraig.com.au/Images...ecs%202009.pdf
Could also be used to drain a swimming pool in a pinch.
Old May 23, 2009 | 10:03 PM
  #39
c32AMG-DTM's Avatar
Mount it somewhere in the bay where it could be seen, and people might assume you're running a twin-charged setup.
Old May 23, 2009 | 10:05 PM
  #40
C32 AMG
No doubt! Looks a lot like a turbo at a quick glance.lol
Old Dec 18, 2013 | 07:43 AM
  #41
Tommyboy928's Avatar
89 SL500 Silver ,97 SL500 Carlsson 04 Mercedes SL55 AMG , 07 Mercedes SL55 AMG convertedBlack series
Upgrading to what??
if talk about intercooler pumps for Sl55 , it is a change in 2007 to a bosch nr10 pump , ANYBODY knows the flow of that new pump? they say no need change to CM 30 if have that one.
Kleeman has another pump with this specs
3 times up VS normal is 100%
And it will do it at 11 PSI
8.7 G.P.M. compared to the OEM pumps 3.00 G.P.M. flow rate IS 11,3 LITER , AMAZING SMALL AMOUNT .
SO IF IT IS US GALLON 1 X 3,78 LITER IT IS 32 LITER PR MIN ON Kleemann PUMP , WOULD LIKE MORE ACTUALLY, IF SYSTEM COULD HANDLE IT , BUT maybe the lines not big enoght
Old Dec 18, 2013 | 08:03 AM
  #42
high flow pump
if have extra Radiator and use this pump , are you shure y not flow the water so fast that radiator has no time to cool the water ?
Old Dec 19, 2013 | 06:28 PM
  #43
gwin's Avatar
C32 AMG, 997, Mustang '66
IF you're changing the pumps for performance reasons then you've got it all wrong.
The recommendation to change to CM30 is about reliability, the Bosch are known to have higher chance of dying, and hence the CM30 are recommended as a close enough replacement.
If you're doing funny things to your car for performance, then you need to research bigger/more powerful pumps as well as a higher flowing IC with bigger coolant pipes etc.
I think you're asking the wrong question for the wrong scenario.
