82mm TB for C55
Old Nov 28, 2013 | 01:12 PM
  #51
alfred dahdah's Avatar
w 203 c 55 amg
That's interesting. I though its very hard to tune m113k engine with maf sensor,
Good job
Old Nov 28, 2013 | 02:09 PM
  #52
AMGSC's Avatar
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
Good job
DynoComp and Weistec were both able to do it running over 12 psi.
Old Nov 28, 2013 | 02:17 PM
  #53
w 203 c 55 amg
I actually have a kleemann supercharger,headers and cams.
I am thinking of changing the entire engine transmission ecu wiring to m113k engine.then some mods on the engine.
i was told that this is the best way of doing it.its an expensive work to do,but i might get some advice from you,since you have done a great job !!!!!!!
Old Nov 28, 2013 | 02:19 PM
  #54
AMGSC's Avatar
It will work but you still need a voltage clamp.
Old Nov 28, 2013 | 02:23 PM
  #55
w 203 c 55 amg
I will send you pm to ask you some questions(fuel pump required,diff ratio,etc)
Thanks for your help
