noob here.
so i've been searching (in the rare event that it works) and it looks like the 185mm requires a fuel pump upgrade as to not run lean up top. is this correct? am i better off just going with a c3 supercharger pulley or 178mm pulley for safety?
YO DINGLEBERRY! J/k Originally Posted by Dingleberry
noob here.so i've been searching (in the rare event that it works) and it looks like the 185mm requires a fuel pump upgrade as to not run lean up top. is this correct? am i better off just going with a c3 supercharger pulley or 178mm pulley for safety?
, No fuel pump needed. Just a custom tune for the 185 and ideally, a custom dyno tune. You can have LET/Eurocharged put a tune on your ECU for the 185 or you can rent their remote tuning kit in which they send you the kit, you go to a dyno, hook up the kit to a laptop and they will remotely tune your car from your dyno runs.
I have a 185, was running a little lean and then did a dyno tune from LET. I'm no longer running lean.
Also of upmost importance is upgrading your cooling mods to compensate for all the extra heat the 185 will generate. Without a Heat Exchanger upgrade, I wouldn't run a 185. Along with all this is getting an upgraded intake so you can suck more air as well.
Good Luck! It's soooooooo worth it!
Plus the people at LET/Eurcharged are great guys.
http://www.eurocharged.com/index.php?page=shop.product_details&flypage=flypag e.tpl&product_id=78&category_id=6&option=com_virtu emart&Itemid=61
http://www.eurocharged.com/index.php?page=shop.product_details&flypage=flypag e.tpl&product_id=76&category_id=6&option=com_virtu emart&Itemid=61
http://www.eurocharged.com/index.php?page=shop.product_details&flypage=flypag e.tpl&product_id=20&category_id=6&option=com_virtu emart&Itemid=61
REQUIRED:
1) tune is a must to go WOT with a 185. its unsafe otherwise.
Highly Recommended:
1) Heat Exchanger - wont see potential full power without it
Recommended:
1) step cold spark plugs for the extra boost/power
2) an intake would be helpful to improve the air flow up top or else it might choke, but its not really required.
3) Separate coolant circuit
Wouldnt Hurt:
1) upgraded IC Pump
2) -10 fan mod
3) tstat (assuming you separate your coolant circuit)
Highly Recommended:
Recommended:
Wouldnt Hurt:
1) upgraded IC Pump
2) -10 fan mod
SPONSOR
loungn14
SPONSOR
close
- Join DateJul 2007
- LocationHouston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I driveEurocharged Performance ML63 and TT lambo
Liked:152 Times in 110 Posts
you gonna need new back tires pretty soon!!!
