Direct Buy Warranty (Lengthy)
I am currently looking for reputable 3rd party extended warranty since my C32's mileage is getting up there. According to lots of current customer reviews (from June to Oct.1st '09) this company is legit has great customer service, low rates and never increase rates when renewing.
Let me know if you are a current customer and your experience with them. Is this too good to be true??
Here's what I've been quoted:
My car: 73,000 miles, '03 C32, I currently live in Alabama
My quote:
I use this promo code to get free $250 gas card plus 30%off : gas20 (Until Oct. 30, 2009)
DirectBuy Warranty
Corporate Headqaurters
402 Main Street Suite 100-306 Metuchen,NJ 08840
Phone: 1-888-865-4484
Fax: 1-888-574-9086
Coverage: Gold Coverage with Unlimited Mileage
Deductible: $0
Added Coverage Options: Seals & Gaskets and Super Turbo/Charger
Term: 3 Years + Unlimited Mileage
Down Payment: 299.98
Here's my payment breakdown:
Additional Coverage: $99.98
Savings: -$1463.98
1 Payment of: $2415.97
Today's Payment: $299.98
12 Payments of: $176.33
Final Price: $2415.97
Here's the protection description:
Covered Items:
Engine
Transmission
Steering
Cooling
Electrical
Fuel Pump
Drive Axle
Brakes
Differential Assembly
24/7 Service
Towing
Rental Car
Locksmith Service
Out of Gas
Dead Battery
Trip Interruption
Protection Coverage Chart*
Covered:
Gasoline/Diesel Engine
Cylinder block, cylinder head(s) if damage by internally lubricated parts. All internally lubricated parts including: pistons, piston rings and pins, crankshaft and main bearings, connecting rods and rod bearings, camshaft and bearings, pushrods, rocker arms, valves, valve springs, seats and guides, lifters, followers, oil pump, timing chain, timing belt and gear. Harmonic balancer, dip stick & tube. Valve covers, timing cover, and oil pan if damaged by internally lubricated parts; vacuum pump, engine mounts.
Transmission
Transmission case, transfer case and pan if damage by internally lubricated parts. All internally lubricated parts including: torque converter, vacuum modulator, internal linkage, and transmission mounts.
Drive Axle
Housing(s) and cover if damage by internally lubricated parts. All internally lubricated parts including: axle shafts, universal joints and yokes, constant velocity boot or joint or both, wheel bearings/hubs, drive shaft center bearings, supports, propeller shafts, locking hub mechanisms.
Steering
Steering box and rack and pinion unit and all their internal lubricated parts including: power steering pump and cylinder, main and intermediate steering shafts and couplings, steering knuckles; pitman arm, idler arm, tie rod ends and drag link.
Brakes
Non - ABS master cylinder, power booster, calipers, wheel cylinders, hydraulic lines and fittings; proportioning valve, backing plates, springs, clips and retainers, self-adjusters, parking brake linkage and cables.
Electrical
Alternator, voltage regulator, starter motor, starter solenoid, distributor (excludes cap, rotor and wires), window regulator, heater A/C blower motor.
Heater and Air Conditioning: Evaporator, condenser, compressor, compressor clutch, receiver/drier, field coil, accumulator, A/C high/low pressure compressor cutoff switches and heater core.
Cooling
Radiator, radiator fan blade and motor, fan clutch, water pump.
Fuel
Fuel pump, metal fuel injection lines/rails, fuel tank and metal fuel internal lubricated parts including: waste-gate, vanes, shafts and bearing.
(Front and Rear) Differential Housing (if damaged by internally lubricated parts), Axle Shaft, Ring and Pinion, Bearings, Bushings, Washers, all other internal parts contained with the differential assembly.
Super/Turbo Charger: All internal parts; Housing is covered if damaged by the failure of an internally lubricated moving part.
Seals & Gaskets: Are covered for the following assemblies; engine; super/turbocharger; transmission; drive axle(s), brakes, and air conditioning.
Not Covered:
Non-Covered Parts - Leak detections and/or any of the following parts: carburetor; throttle body; battery; battery cables; shock absorbers; struts; manual transmission clutch friction, clutch disc and pressure plate; throw out bearing; pilot bearing; clutch master and slave cylinder; manual and hydraulic linkages; distributor cap and rotor; wires; safety restraint systems (including air bags); glass; lenses; head lamp and projection lamp assemblies; sealed beams; light bulbs; fuses; circuit breakers; telephones; television / vcr; electronic and satellite transmitting / receiving devices; brake rotors and drums; exhaust system; evaporative and exhaust emission systems; oxygen sensors; weather stripping; trim; moldings; bright metal; chrome; upholstery; carpet ; zippers; nuts, bolts, and fasteners; cup holders; dash pad and vents; seat frame; seat frame recliner mechanism; paint; outside ornamentation; inside and outside door handles; mirrors; hinges; lift gate and hood supports; hubcaps/wheel covers; bumpers; body sheet metal and panels; body parts; frame and engine cradles; body mounts; mounting brackets and structural body parts; vinyl and convertible tops; tires; wheels/rims. Seals and gaskets are covered only if needed in conjunction with a covered repair for vehicles with up to 80,000 odometer miles at the time of the Breakdown; near object avoidance systems; speakers and wiring.
Scheduled Maintenance Service and Adjustments - Maintenance services and parts recommended in the Vehicle Manufacturer's Maintenance Schedule. Unless required in conjunction with a covered repair, the following are not covered under this agreement: mechanical adjustments filters; lubricants; coolants; fluids; refrigerants and the service operations necessary to replace them. Other normal maintenance services and parts, including, but not limited to: alignments; wheel balance; tune ups; sparkplugs; spark plug wires; hoses, belts; brake pads; brake lining; brake shoes; wiper blades; squeaks and rattles; water leaks; wind noise; thermostat are not covered.
It's also becoming very hard to find anyone that will cover AMGs so, if you have someone willing to cover your 32, I'd say jump on it.
M. If Your Vehicle has been altered and does not meet manufacturer’s specifications, including but not limited to, any custom or add-on part, all frame or suspension modifications, lift kits, oversized/undersized tires, emissions and/or exhaust systems modifications, or power train modifications will result in a claim denial.
VRP Headers - LET 185mm Pulley - LET Tune - C3P Intake - CM30 Pump - C3P HE - Phenolic Spacers - TVT Modified T-Stat - Green Filters - Magnaflow Front Cats - Resonator & Rear Cat Delete - H&R Springs - Denso IK22 Plugs - Magnecor 8.5mm Wires - Weltmeister Quad Exhaust - CF diffuser, spoiler, mirror covers - 18" AMG Turbine Rims
When your claim is denied, as it inevitably will be at some point, it will always be MORE costly to fight it, then to pay for the repair.
I prefer "exclusionary" warranties. i.e. "we cover everything EXCEPT the following..."
My quote:
DirectBuy Warranty
Fax: 1-888-574-9086
Deductible: $0
Savings: -$1463.98
Covered Items:
Engine
Transmission
Steering
Cooling
Electrical
Fuel Pump
Drive Axle
Brakes
24/7 Service
Towing
Rental Car
Locksmith Service
Out of Gas
Dead Battery
Trip Interruption
Covered:
Transmission
Drive Axle
Steering
Brakes
Electrical
Cooling
Fuel
Not Covered:
Gaylon L Murphy
943 Peachtree Street Unit 1609
Atlanta GA 30309
404 989 0063
There is a lot of information out there about these guys.... All you have to do is google them and start reading and you realize fast why the price was so low for the warranty you get from them....
. Direct Buy Auto Warranty: They say that they are direct administrators of the policy and offer Platinum Elite coverage for this AMG - 3 yrs/36k miles/0 deductible/ service anywhere but preference for MBZ dealerships for $3100.
2. Carchex: They offer Platinum coverage 3yrs/75k miles/$500 deductible/ service anywhere for $6224. They also offer a Gold level, lesser coverage - 3yrs/36k/$500 deductible for $4479.
3. Drive Trust USA writing a policy for Lasalle Warranty Co: (Specialize in AMG/ Maseratti and Lotus, exotics) 3 yrs/54k/$500 deductible/$4348.
Of the three the Direct Buy folks were the nicest on the phone when I called and the most prompt in sending me quotes and contractual information to review in making my decision. I asked for references and they supplied two websites:
1- http://autowarrantybureau.org/
2- http://cawa.us/index.php
As you can see they are full of anonymous reviews which speak positively about the company. Never satisfied with reviews without context I drilled down with Google and sadly I didn't have to drill too deep:
http://www.yelp.com/biz/direct-buy-auto-warranty-metuchen
http://complaintwire.org/complaint/p5gBAAAAAAA/direct-buy-warrnty
http://www.pissedconsumer.com/?option=com_search&Itemid=38&searchword=Direct%20B uy%20Auto%20Warranty&go=
http://www.complaintsboard.com/complaints/direct-buy-auto-warranty-california-c456737.html
I have never seen complaints of this breadth and scope of a company that wasn't under indictment or civil complaint. I can get over the occassional angry "yelper" who is a serial complainer but these complaints span a period of years and are decently geographically dispersed. Out of extreme fairness I actually sent these links to the nice salesman from DB and invited his response. I wonder if I'll ever hear from him again.
Needless to say since the car got such a clean bill of health from the MBZ dealership in an independent pre purchase inspection and has such low miles I am going to just bank the money that I was going to spend on a policy and make a rainy day fund for the car instead of giving it to these guys and depending on them to watch out for me.
