22 spoke wheels for C32
Old Oct 17, 2009 | 04:38 PM
Gene Gorman's Avatar
05 SL55, 10 C63, 12 SLK3, 20 S560, 08Bentley GT Speed, 16 Aston Martin Vanquish
Will the wheels from a SL55 fit either a C32 or a SLK32? The wheels are 8.5x18 and 9.5x18.
Old Oct 17, 2009 | 06:42 PM
moosejaw's Avatar
none
i think you may have issues with the offset but i have seen them done on a W203 before.
Old Oct 17, 2009 | 07:08 PM
superstar's Avatar
03 R230 SL55 / 94 W124 E500
No issues at all on the C55. The C55 and C32 are the same. No rubbing if you install the right tires size.
225/40/18 front
255/35/18 rear
Old Oct 17, 2009 | 08:57 PM
kiamcoj's Avatar
2012 CLS63
225/40/18 front
255/35/18 rear
What tire sizes are you running if you don't mind. Are you lowered?
Old Oct 18, 2009 | 04:48 AM
superstar's Avatar
i am not lowered and running :
225/40/18 Front Wheel size :18x8.5 offset 30
255/35/18 Rear Wheel size :18x9.5 offset 33
Old Oct 18, 2009 | 12:36 PM
kiamcoj's Avatar
2012 CLS63
Do you feel that if the car was lowered that you would rub?
Old Oct 18, 2009 | 02:35 PM
superstar's Avatar
Probably yes! Because I have installed 235/40/18 on the front and the front tires were rubbing . Other members installed 255/40/18 on the rear and they were rubbing on the back. So i would imagine that if you lowered your car, you might rub!
Old Oct 19, 2009 | 09:26 AM
SilverBulletAMG's Avatar
C32 AMG
I'm lowered and run 235/255 on the same rims. I had to change the lug nuts/bolts and was rubbing in the front. Ended up removing some of the cover in the wheel well to make it clear. I'd go 225 in the front to be safe.
Old Oct 19, 2009 | 10:57 AM
kiamcoj's Avatar
2012 CLS63
Thanks for your input!
