Transmission is shifting strange
If you have not done it I would recommend it, from personal experience and reading various other articles its seems to help most of the time with shifting issues etc... or do a transmission adaptation reset on the TCU that helps also.
Mercedes-Benz Flex Service Details
apparently crazypotato has figured something out about this issue. the CDI also has the 722.6 transmission. look at what they're doing to fix this same issue that they call "RSN"
http://www.benzworld.org/forums/w211...oning-rsn.html
After a new radiator, rebuilt tranny top to bottom TWICE (warranty) new TCU and god only knows what else, I still have the "jerk" and like many others, have learned to live with it.
The ECU reset trick (also search) has proven to be the most effective way around this, although it's only a temp fix. The issue seems to be with the tq converter and/or the way the adaptive tranny learns, so I'm told by the "pros" anyway.
I didn't read this entire thread since it's been beaten to death, but if I'm just repeating what's already been said, I apologize.
Good luck!
I believe it determines this for the first 45-90 miles, so drive the **** out of it for it to learn to drive that way... lol
Like my Service Advisor says, "These cars are made for the Autobahn, they don't know slow and comfort like the luxury models, so drive it like you stole it and it will drive perfectly every time!"
Throttle TCU Reset:
1. Turn ignition key to the ON (not start) position.
2. Press the gas pedal to the floor and hold it there for 5 seconds.
3. Turn the key to the "off" position (do not remove key), then release the gas pedal.
4. Wait for 2 minutes for the TCU and throttle to reset.
5. Your Done, turn the car on Foot to the floor and drive the **** out of it!
This is good for when going to the track, gets rid of the throttle input lag also.
I've tried the soft reset numerous times and find no real difference. Maybe I am having a computer glitch as MB already upgraded my tranny software.
