A & B Service and Resetting
Does anyone have the breakdown of the A and B services, i.e. the tasks performed by the dealership.? Additionally, how do you reset the computer after you perform the recommended service?
I know I read this info on the forum before, however, I have tried to search for the info again and cannot seem to find it.
Thanks for the help.
Scott
*Pricing is for approximate illustration purposes only, pricing may differ at your dealership, please consult your dealership for current pricing*
A-Flex Service Approximate cost $199 - $249
- Replace engine oil and genuine MBZ oil filter
- Lubricate hood hinges
- Inspect brakes
- Inspect cooling system
- Check & clean air filter (replacement additional)
- Inspect windshield wiper inserts & service windshield washer system (replacement of wipers additional)
- Inspect heating & ventilation dust filter (replacement additional)
- Inspect lines & hoses
- Inspect & lubricate throttle linkage
- Check tire pressure (including spare)
- Check horns, lights, seat belts, tires & brake pads for wear
- Check & top-off all fluids
- Reset Flexible Service System counter
- Wash Vehicle
- Road test
B-Flex Service Approximate cost $299 - $449
- Replace engine oil & genuine MBZ oil filter
- Analyze engine management system with Mercedes-Benz Star Diagnostic System Tester
- Rotate tires (excludes AMG models with staggered wheels)
- Inspect brakes
- Inspect front axle ball joints; & rear differential levels
- Check steering play & power steering clutch
- Inspect Poly V-Belt for condition
- Inspect Climate control refrigerant
- Wash Vehicle
- Road test
Additional Dealer Recommendations
- A/C Evaporator Cleaning - $129
- Fuel Injector Service - $139
- Replace Cabin Air Filter (consult dealer for model pricing)
- Brake Fluid Exhange - $129
- Power Steering Service $169
- Cooling System Service - $149
Factory Recommended Transmission Service
Recommended at 39,000 miles
Vehicles equiped with a .6 transmission - $279
Vehicles equiped with a .9 transmission - $359
Transmission Service Includes the Following
- Remove transmission pan
- Replace transmission filter & pan gasket
- Renew fluid (5 quarts synthetic transmission fluid)
- Road test to verify proper gearshift performance
- Inspect brakes
- Wash Vehicle
- Road test
- Inspect brakes
- Wash Vehicle
- Road test
Allot cheaper
I would recommend performing the oil change at 5000 miles between the 10000 miles full flex services if you want to.I think on the service B if you have a supercharger they service that as well. Other than that they are just inspecting everything to make sure everything is within spec.
*Consult your dealership for exact pricing on your model*
I didn't know the B service was so similar to the A... I like that lube and reset method as long as the car gets regular attention from the owner (who here doesn't check their levels, etc regularly).
I am about to get ready for my service B and while I only paid 140 for service A, I've been quoted about 390 for the 20K B Service. Should I shop around or just go to a non-dealer?
What is the best way to shop for services quotes online?
I would start with as reputable an independent mechanic as you can find on yelp and use a simple service like an A or B to judge if they can handle bigger jobs down the road. My indie charges 99 bucks for and A and 199 for a B service. Reasonably priced and does good work! Hope you find similar!
can you post or PM name of indie shop? i live in the bay area, and looking for a shop to service my car. thanks.
The 99/199 pricing is from these coupons I get with the paper every once in a while. If you bring it up, I'm sure he will give it to you!
