Does the c32/c55/clk55 share front brakes with other MB models
w209 Clk 55 Amg
I wondered a little bit about if our 4piston front brake calibers(w203 and w209) are used on other models in the mercedes range? Like the older e w210 class or s class w220 ? Or any other perhaps?
and does the rear calibers from a w210 fit our model range?
Wonder only because i have been offered some Brabus parts from a w210 and a w220. But i dont know if they will fit my car and have search'ed all around but cannot realy find something about it?
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Wonder only because i have been offered some Brabus parts from a w210 and a w220. But i dont know if they will fit my car and have search'ed all around but cannot realy find something about it?![drive](https://mbworld.org/forums/images/smilies/driving.gif)
a quarter mile at a time
The equivalent C32/55 front brakes can be found on SLK55's, CLK55's, ML500's, ML55's, SL500's, SL600's, and some S and CL classes as well. Keep in mind that although they may look the same, the mounting arms may differ a bit across these models and some years may have gotten these brakes and some may not.
Clear as mud?
no they weren't. The 4-piston brakes on the 2004.5 C230's used smaller brake rotors.
Clear as mud?
Clear as mud?
CLS, SLK, ETC
It's easy to find out what cars share the same breaks and caspers just punch the part# into EPC under search and it will show you all the vehicle they fit.
Super Moderator
Another member recently attempted to retrofit four-piston calipers on his W203.
While appearing to be suitable upon receipt they were, after installation, discovered to be a mismatched pair.
![](http://i209.photobucket.com/albums/bb196/splintersAMG/bdcalouts.jpg)
![](http://i209.photobucket.com/albums/bb196/splintersAMG/bdcala3.jpg)
![](http://i209.photobucket.com/albums/bb196/splintersAMG/bdcal_rotors.jpg)
image credits withheld to protect the victim
Know your seller if you’re sourcing them privately.
Pictures are worth a thousand words: https://mbworld.org/forums/2744315-post896.html
Although the 2004.5 brakes are indeed 4-piston, they are much much different than the other 4-piston setups.
Hey Splinter I honestly don't think either of those two calipers are from a 2004.5. I think they are both from something else.
The link you provided clarifies what you were trying to prove
you are correct
The pic splinter provides I cant tell what that is from??
The caliper misspelling is a running gag as the OP made a typo in the first place and we were running with it.
Once again I cant believe I am wrong....
you are correct
you are correct
you are correct
some SLK55's were fitted with 6-piston calipers and later were switched to 4-piston calipers due to customers complaining about brake squeal issues.
The stock 13.4" rotors + 4-piston fixed calipers are in essence a mild big brake kit in itself. With proper pads and brake fluid it is a very capable setup.
w209 Clk 55 Amg
Sorry for my bad english spelling... CALIPER from now on i got it. Its not so easy to speak 5 different languages and then also spell everything correct. sorry for my mistake.
2006 C55 AMG White/Ash
The calipers on a C55 are made by Brembo. It's in the casting on the back side of them, can't miss it, pretty big. If you are under your car and look over you'll see it.
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
