Extreme belt wrap setup
What plugs are you using? Switched to the copper plugs 3 stages colder and it may not have been a good choice. Going back to Denso IK20s.
btw... ASP is modifying my crank pulley from 150mm to 170mm for only $250. Lee seems to be a great guy. But I won't even install this modified spare crank pulley until I get the MAF issues sorted out first.
Also just measured the pulleys on an E55K and confirmed that the SC pulley is 90mm and the crank pulley is 155mm so the drive ratio is 1.72. Therefore a 180mm modified ASP/Renntech/LET pulley achieves the same 2:1 drive ratio as a Kleemann SC pulley with a stock NA crank pulley which is 75mm.
NGK BCP7ES
Cool, thats a good price.
The good thing is that Cory assured me that they have also NEVER failed to solve custom applications with any car physically brought to them.
(11 to 1 ) Pistons , I think you indicated you had custom (9.5 to 1) pistons.I've got a MP-112 Gen 4 , you have a IHI blower set up
When I first started to fine tune the set up I had a 2.8" / 71mm blower pulley and a 70mm idler. On the street & also on the dyno , my boost gauge would read 5.3 - 5.4 psi @ WOT and hold it there . No tapering off. The A/F ratio was perfect, 100 psi fuel pressure. Stock & recently cleaned injectors. No knock sensor voltage spikes. I then decided to go for more Boost. I called Southflordiapulley Hdqs. & got a new 2.6' / 66mm blower pulley. I lost some belt warp / Contact area . So I got a 3.55" / 90mm single bearing idler from a Mustang set up. Took 3mm off the OD, 3.42" / 87mm , as so it would clear the Pulley mounting Bracket & Thermostat hsg. Got it Hard coated anodized. Now I'm at 6.6 Psi At WOT . I have a little more belt contact patch, also. If this works out I'm going to have a Double ceramic bearing pulley made. There still no indicate of slip with the stock or with my new setup. My car runs great
Cheers _PTEngineering
Just heard from Lee at ASP that he accidentally put an 8rib outer ring on my stock pulley!!! Should I accept that or make him redo it?
Make him redo it, unless you plan on switching all your pulleys to 8 rib
Sorry about so much detail but I just can't wait any longer for the final test results on the dyno and track. btw..I paid him $350 to install my 5-gal trunk resevoir. Is that a fair price? Final alignment and dyno tomorrow!!
As for Lee, I said OK for now since the extra two ribs won't make any real functional difference other than looking funny.
Sincerely hope your dyno goes well tomorrow, but forgive me when I say "I'll believe it when I see it."
Best of luck.
The current resister adjustment narrowed the band width too much. Quoted cost was $1200-$1500. Then if it goes over 5 volts I will need a larger MAF housing like the ABACO product as well. Gary feels that the stock injectors and pump should be OK unless I add a much larger crank pulley.
I am now working jointly with Vadim and his partner Gary....
http://www.gksystemsinc.com/Joomla_RT_Hyperion/
btw...Dyno was aborted before max RPM was attained due to dangerously lean condition up top. Prelim was 460rwhp at 4000rpm I think. Still waiting for the chart to be emailed to me but it's really meaningless until I get it to run right.
Btw, 460whp at 4k rpm is alot!
