WHOA?! HEELLPP!! FLOOD IN THE TRUNK!?
Old Dec 13, 2009 | 12:03 AM
SGTzAMG's Avatar
Veteran: Army
02 C32 AMG, 05 SL55 AMG, 09 SL63 AMG, 14 E350, '18 G550, 92 300ZX & 15' GL63 AMG
Angry WHOA?! HEELLPP!! FLOOD IN THE TRUNK!?
S**T!
F*c*!
ARRRGG!!
DAMN!
...sigh..
the benzino has been sittin outside for 2 damn days, and it HAS BEEN POURING like crazy here in sacramento...WELL..as i JUST now looked in my trunk...at the Left cubby, storage area, that entire cargo, cubby, storage area is FLOODED with water!
OH MAN! i had to vacuum all that water out from there..i just dont know where its coming from!? :dunno:
this is bad, all baad! all the electrical wires thats in that area has been soaked with water
anybody know where, and what could be causing the water to get in there??
thanks guys in advance...
Old Dec 13, 2009 | 12:57 AM
W203Ramos's Avatar
'03C32 Obsidian Black, '76Toyota Celica GT TRD, '12R350 4matic Arctic White, '06 ML 350 arctic white
Originally Posted by MiZterC32AMG
S**T!
F*c*!
ARRRGG!!
DAMN!
...sigh..
chong, hassel meng....sorry to hear that 'tol.... will look at my trunk area later if i have any ideas. but all I could think of is the drain ports make sure water is indeed draining. might be clogged with bits of leaves or something, this would be the best case scenario coz all you have to do is clear that stuff up. my next guess would be the rear glass panel hopefully there are no leaks. GL
Old Dec 13, 2009 | 01:14 AM
SGTzAMG's Avatar
Veteran: Army
Braad! nakaka pikon men! the fact that its not mechanical u know, and its all body ****, out of my realm!
pero i have a clue where its coming from, its coming from one of the platic lining that goes along the rubber weatherstrip? kasi in the trunk, right below where that plastic lining is, the actual sheet metal is rusted bro!
so i improvised and put silicone sealant around taht area...layers after layers..hopefully...itll help out!?
ewan ko man, its just annoying, and the rain is not being nice dude.
been on duty for da army 2 days, and i drove the Z and left the C32 sa labas, and its been raining like crazy here man.
And to come home to tihs kinda sucks!
Old Dec 13, 2009 | 01:16 AM
W203Ramos's Avatar
pm sent
Old Dec 13, 2009 | 01:22 AM
W203Ramos's Avatar
'tol...i think when summer comes around you just have to take that weather stripping off and bondo it nice and smooth, won't see it anyway....maybe I'll be in cali by that time... I visit my sis often in walnut. anyway, hope it works out. if you got a garage put it in there in there for now. but yes it sucks when one of ur rides is sick!!!
Old Dec 13, 2009 | 01:40 AM
SGTzAMG's Avatar
Veteran: Army
true true true!
kita kits when ur in Cali man! just holler!
Old Dec 13, 2009 | 02:28 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
i would disconnect your battery. The electrics should be ok, long as you don't run any current through while its wet. Maybe check the little hole behind the license plate. There should be screw and behind it a rubber seal. it might that. Other then that, its probably the rear window like w203ramos said.
Old Dec 13, 2009 | 03:31 AM
SGTzAMG's Avatar
Veteran: Army
OH FORSURE MAN!
ill make sure i check the license plate as well!
but as far as the "flood"
Ramos helped me out and dobule checked some issues for me, but apparently, the plastic molding thats on each corner along the weather rubber stripping needs to chekced for clooggged debris and needs to be cleared...im basically having water back up.
..it just sucks because the rain is not letting me work on it :-/
as far as the wires thats soaked, i dont even know where and what those wires for, but i havent started the car or anything at all, just unlock/lock/trunk open from the key fob.
Thanks man for the input about the license plate! def look into it soon, whenever the rain subsides!
Old Dec 13, 2009 | 03:40 AM
TemjinX2's Avatar
long as it doesnt reach the rear sam. The rear sam as some live wires even when the car is off. So if its close to the rear sam, you should disconnect the ground on your battery.
Old Dec 15, 2009 | 02:47 AM
SGTzAMG's Avatar
Veteran: Army
actaully, the rear sam got soaked with a lil bit of water :-(
i JUST realized that now the lock that locks/unlocks my fuel filler cap doesnt work...the actual assebly itself WORKS, its the wiring...everything else seem to work fine? i dunno..i went ahead and cleaned some debris from the plasting moulding trim around the same area where the rubber weather strips are at...also i went ahead and had blew air underneath the plastic moulding where i found soggy/rotten leaves and dirt build up and such..hopefully no more clogged drainage and rain water backing up in my trunk!
Old Dec 15, 2009 | 06:24 PM
BryanW203's Avatar
There are 3 push clips that are on the outside of the trunk seal that hold down some plastic trim pieces. Those pins/clips are 1 time use only, if your trunk has ever been wrecked or wroked on and those clips were reused and not replaced water is leaking in. You can reuse the old ones, but you will want to reseal them with some sort of silicone.
You can see the clips on the right and left side of the trunk, but the ones you are concered with are on the top section.
Old Dec 15, 2009 | 11:52 PM
TemjinX2's Avatar
i would just check all the fuses.
Old Dec 16, 2009 | 01:13 AM
SGTzAMG's Avatar
Veteran: Army
THANKS MAN!
i did check, and all the clips does not seem like they've been tampered with, until i tried, lol theyre super hard to pry off, i stopped tyring. but other than the the clips seemes to have been on there ever since..
Old Dec 16, 2009 | 01:14 AM
SGTzAMG's Avatar
Veteran: Army
all the fuses are good,
although...when i stareted to car ealier, error popped up on the computer sayhing that my tail light is F'd up, and my back up is running...
but i pretty much disconnected the tailight bulb from each side, and seem started to work again... *shruggs* siighh..
Old Dec 16, 2009 | 01:33 AM
TemjinX2's Avatar
well good luck, once you have the electrical gremlins..there hard to track down.
Old Dec 16, 2009 | 06:33 PM
W203Ramos's Avatar
those damn gremlins....bro wait for a nice sunny day and just open up everything let it air out and perhaps after doing so you could go to home depot and get a couple of those dehumidifier bags that are used for basements and throw a couple of those in the trunk. sounds silly but a friend of mine had a e320 and got rained on with all the windows down incl. the moon roof!!!anyway to make the long story short he dried up most of the water manually and then he put a dehumidifier inside the car it actually sucked out almost a 1/2 gallon of water overnight.
GL
Old Dec 17, 2009 | 02:36 AM
SGTzAMG's Avatar
Veteran: Army
GL
Salamat brad as always!
yea taillight works, i just uplugged it and plugged it back in and wala!
its funny this happened, its been dry for 3days now ewan ko, im ready for a C63 hehehe
Old Dec 17, 2009 | 08:25 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
the only way water can get into your trunk is IF your trunk seal are f-ed OR trunk latch is loose and not holding the trunk down for proper seal OR your tail light cover is loose.
Old Dec 18, 2009 | 01:04 PM
SGTzAMG's Avatar
Veteran: Army
thanks frank, i will check into that. so far though the trunk seals are fine. the rubber is good, no wears nothing. but ill check the trunk latch for loosess and tailight cover.
THanks guys for your input!
