camber kit help
1 Post
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
Here is a link to better ones. I have them on my car and they don't squeak.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Super Moderator
Saw GLK4matic’s suspension links firsthand at Famoso.
They’re stout, with heim joints sufficient for a Pro Stock machine.
Lensolo and speedybenz have previously supplied them, but their lengthy delivery schedule precludes a recommendation.
GLK4matic fabricated and installed a set on jangy’s W211 with favorable results. Was pitching rarfinancial and juicee63 when I took the liberty of asking if he had made anything for our Cs. Indeed he does. Struck me as knowing the trade, intelligent and customer focused. Although not a sponsor here, he has earned a satisfied following at myMB.
link
edit: MB Arts = GLK4matic
link
'06 C55 AMG
I've got a set of GLKmatic's I plan on installing this week. The quality appears to be superb, I cant wait to get them installed! I'll be doing a DIY for them as well though installation appears to be very straight forward.
AMG C43, 1999
1 Post
GLK Matte Silver|MB Arts strut tower brace|MB Arts rear brace|Shaved door and bumper trim|K&N's|
Wow That is a lot of negative camber. Definently not a good thing for a drag/performance vehicle that depends on as much rubber making contact with the pavement as possible.
Moderator Alumni
Splinter gots ya covered w/ all of the options. Although, I am starting to think my adjustable camber arms are the cause for much noise from my rear suspension
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
They make three levels of kits, street, street/strip, and a race. My ex crew chief bought all 3 for his M5 for road racing.
His opinion, not mine as I never saw any of them.
1. Street kit, pure garbage, threw them out
2. Street/strip, extremely difficult to install, very limited adjust ability
3. Spherical end joints, truly a track only piece but the best out of the three.
He installed the street/strip, and was disappointed with them. Quote "Not worth the hassle"
Just FYI
Moderator Alumni
Former Vendor of MBWorld
C55,SL55,C63
I just scored a set of Mb Arts camber arms. very excited to get these bad boys. They will be on the track Saturday. I could not hook at Famoso, so i will know right away if they solve my problem. i'm betting they do.
Moderator Alumni
Hooley, Adjustable arms seem to offer the easiest and greatest adjustment... IMO, its the way to go...
edit: oh and the kmac bushings were not known to be completely quiet either...
Kmac only makes the eccentric bushings for the f/r and as such their is only 1 "stage". The arms for the rear are the way to go. I wouldn't bend the stock units as you are inviting fatigue points.
I am surprised that you don't have coilovers. Irrespective of ride height, the adjustable shocks with stiff rear and soft fronts would likely help your launches. With the ride height you put the camber wherever you want. What size tires and rims are you running now? Be forwarned that 265's are problmatic. My stinking z starts rub on dips even though I have the rear fenders professionally flared and with the shocks set at 14 when I drive in the canyons. I am also going 100+ though...
I just thought about it and I think I have spent as much or more on my handling and braking as your have on just your engine! It's all about what you like I guess.
1 Post
SRT-6
Be sure to post up your impressions. My solution was economical but heavy and noisy. I'm getting under the car this weekend to look for a solution to the creaking. As far as adjustment, I'm currently running -2.2 camber in the rear but will be going closer to stock soon. It was an experiment for the road course and it turned out to be too much. (unpredictably loose)
Les
Les
C55,SL55,C63
Camber arms are installed!It was no small task with my setup. HR lowing springs 18x9.5 rims with 265s. I had to beat my fender wells into oblivion to get the camber i wanted, without rubbing. Don't get we wrong It came out awesome. I found out I toes in like a ****. Got that taken care of. As we sit right now, My car is driving so much better around town. Its something only an owner would notice if you know what I mean. These Camber arms are well worth the money. Big thanks to MBArts. They helped fix a problem I feel has been slowing me down. I will have some track results tomorrow for all you guys.
IF it means anything to other W203 drivers. MBArts Camber Arms have my approval.
