SRS Light came on
. There has to be a DIY out there..
Stealership wanted $1000 to replace the sensor in the passenger seat.
Any cheaper or DIY way around this?
SRS light is not a safety hazzard as the air bags will still deploy in the event of an accident that's why I am having a hard time justifying spending a grand to fix something that is just mildly irritating.
Seats and tracks - Front seat components - Sensor - Child seat recog
Child seat recog 2002 - 2004
Add to Cart Contact Us
OEM Catalog
Item Number MSRP Core Price Price
2038215579 $202.00 $0.00 $151.50
if you change it, you will need somebody with star to reset your srs light
https://www.getmercedesparts.com/oem...des-parts.html
OEM Catalog
Nice! $151 is fair enough to fix this prob.
Did you just DIY the replacement? If yes, can you guide us a bit?
OEM Catalog
to start off move the seat all the way foward
take off the 2 torx bolts on the back rail
then move the seat all the way back and allthe way up.
remove the the 2 torx bolt in the front of the rails
at this point you willbe able to tilt the whole seat back in the maner that i will be resting on the rear seats (dont worry about how the align since they have guide pins)
at the bottom of the lower seat cusion you will see a bar atached by 2 brackets (plastic rivet bracket) well there will be black rivets in them, with needle nose plyer simply pull the black rivets off ( all 4 of them it took me 2 hours to figure out that they dont unscrew lol )
now come the tricky part those bracket self locking on the seat so you will have to get flat head to pri them out i used the wrachet as a hamer the back of the flat head while i was trying to pry... it is painfull.......
warning the is a strong possibility that you will break the braket which they run for around 20 bucks a piece.after you get done with the brackets you will see that there are wires holding coming from seat. cut all the zip ties.
If you have heated seats there should be to wires. folow the wires i will lead you to some type of hub unit where they all all connect. there shouldbe 2 gold torx screws, take those out.
if you look on the side of the hib ther is somewhat of a panel that comes off , take it off.
now disconnect the yelow connector on the side that is not coming from the seat. after that you will notice the seat connector will be captive in the hub. slide the connector downward to take it off * if you have heated seats you will notice the conector is shared with the motion motor for power, for me i spliced the wires, i didn't want to wait time figuring it out.
anyways at this point the bottom cusion should almost be out. you will notice there are 2 springs that suport the seat just pull the cuision foward and up .
if you do everything right you should have the cuision on your hands thinking i cant beleive im doing this ****
well flip it upside down, you will notice clips holding the leather undo all the clips.the ocupancy sensor is right between the dark phome and the leather piece.
do not remove the whole apholistery just enough to remove and replace the sensor . after that tis self explanatory reinstall in revers order. i hope this help i will try to post a DIY with pics when i get some free time.
