Help with my symptoms. Belt slip?
Old Dec 18, 2009 | 10:29 AM
Panzerknacker's Avatar
GL 350 Bluetec
When under full throttle sometimes the car will have a loss of acceleration when im over 4500 rpm. It is sudden and then the car will have full acceleration again. Like I have had some sort of fuel cut off point or supercharger disengaged or something, maybe even a misfire. Like I said it will lose power then it will return immediatly on its own. It doesnt happen every time I floor the car, just occasionally. There are no CELs or any other warnings on the dash. Even tried turning off ESP to make sure it wasnt that. Been searching and reading old posts and couldnt come up with an answer.
I have replaced my stock IC pump with a CM30. The symptoms are much different than a bad IC pump, this is a sudden violent loss of acceleration then everything comes back. Doesnt sound like glycol contamination either, this is only at high rpms under full throttle. Throttle position sensor, maybe... but it is intermittent and car runs fine the rest of the time.
Im kind of leaning towards a belt slip. I replaced the belt when I did my pulley kit about 2k miles ago. What are the thoughts of the other c32 owners.
Old Dec 18, 2009 | 10:42 AM
Robert AMG's Avatar
Cls63 & C32
at low speed or high? over 120mph?
Old Dec 18, 2009 | 11:17 AM
GL 350 Bluetec
No not 120+ mph. Like, at the end a highway onramp is when its happening, so top end of 2nd and 3rd gear. Dont have anywhere to go to the top of 4th lol.
Old Dec 18, 2009 | 11:23 AM
testknight's Avatar
CLS55
I know you said you already reaplced the pump...but to me that's exactly how my car acted with a bad one. It was sudden and violent, I'd floor it and then it was like someone put on teh brakes...my head would even bob forward, then after that I could hammer the peddle and it just would really take off (no S/C).
That said, you're probably right that its not, but the new pump could have failed (however unlikely) but just to make sure test this out with a cold car and see if you get the same issue, if it only occurs after a little bit of driving, then maybe it is the pump.
Old Dec 18, 2009 | 11:41 AM
GL 350 Bluetec
I had a bad pump, hence I replaced it. This feels much different. Maybe it is still something IC pump related. Pump not turning on when it should and thats why it is doing it when I first get on the highway. Or maybe a flow issue. Edit: I have made sure I hit enough RPM before entering the highway to ensure pump should have turned on.
It is kind of hard to recreate the problem thats why I am having a difficult time describing.
Old Dec 18, 2009 | 11:50 AM
Velociabstract's Avatar
SRT-6
ESP can cause what you describe, even turned off. Depending on the RPM, if you get too much wheel slip it will intervene (cut power drastically) or up shift early. At least that's how my SRT-6 reacts. I have a data logger which is how I found out what was going on. I hope thats all it is.
Les
Old Dec 18, 2009 | 12:00 PM
GL 350 Bluetec
Guess I would have to put it in dyno mode.
Old Dec 18, 2009 | 12:15 PM
MRAMG1's Avatar
S600, GL450, GLC 43
What pulley did you go with?
It sounds VERY similar to an over boosting symptom, where the engine would shut down. Then it would come right back, because the sensor no longer sees boost.
Another, potential issue, could be HIGH IAT's due to the new boost, hence it pulls timing like a freight train, and as soon as you go back, it has power. So do you still have the stock HE?
Note: Over boost does throw a CEL.
When in doubt, call Jerry or Jake at Eurochrged. They have experienced it all on a C32, trust me, and they are VERY happy to help a fellow nut
One more note: If the belt was slipping, you would see black residue around the blower pulley fairly easy. Also, it would not shut off so to speak, it just wouldn't pull as hard. A shut off is something from the ECU I would wager.
Old Dec 18, 2009 | 12:18 PM
GL 350 Bluetec
I have a LET 185mm pulley, and I am running the stock HE. The thoughts had crossed my mind that it could still be reaching a IAT that was too high, or a boost level that the engine didnt like.
There are no CELs.
Old Dec 18, 2009 | 02:19 PM
AirFrcd's Avatar
03 c32
FWIW - I have experienced the EXACT same issue as you have described, and have replaced every part under the sun to try and problem solve what is happening.
I am also running a belt wrap kit.
After speaking with various tuners, and spending well over $10K in the past 6 mos., the end result has been over boost...
Let's figure this out. The car runs fantastic 99% of the time, with the exception of this intermittent "hiccup" under WOT at the top of 2nd or 3rd...
Old Dec 18, 2009 | 02:37 PM
GL 350 Bluetec
The fix would be to run less boost lol.
But really to use a smaller pulley than a 185 would be an option. Or increase the amount of boost you hit before the ECU plays ref with your tuning. Although then you run the risk of damaging the motor. But MRAMG1 said over boost would cause a CEL and neither of us have one.
Old Dec 18, 2009 | 04:35 PM
MRAMG1's Avatar
S600, GL450, GLC 43
Gentlemen:
Please contact Jerry on an over boost question. Jake and him are VERY knowledgeable on this issue. My statement on a CEL for over boost, is based on other posts from people on this forum. PLEASE use Jerry and Jake for issues. They really are great guys that live for our toys.
Old Dec 18, 2009 | 05:42 PM
GL 350 Bluetec
Originally Posted by MRAMG1
Gentlemen:
Sorry to quote you like the, well word on the streets is that it causes a CEL.
Old Dec 18, 2009 | 07:44 PM
MRAMG1's Avatar
S600, GL450, GLC 43
No problem my friend. It's just when I ran a bigger pulley, I NEVER had any issues. It was however smaller than 185
I hope you get it straighten out my fined
Good luck, and happy holidays
Old Dec 18, 2009 | 08:59 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
if you overboosted you would get a cel. If your on stock spark plugs, then its probably your gap. I had similar issues, it was really bad to the point where i misfired at 120mph. The solution is to get smaller gap spark plugs. Preferably .34-38 gap. I just changed mine out today...hopefully i can test it out in the dyno...soon
Old Dec 18, 2009 | 10:46 PM
AirFrcd's Avatar
03 c32
I am already running the coldest plugs available with the narrow gap - as suggested by EuroTech.
That is not it.
Old Dec 19, 2009 | 08:30 AM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
Is there any way you can do some live data logging? There is a little under $100 gizmo from http://www.carchip.com/ that can log basic OBD2 data including MAP readings. I run a 181mm pulley and only once got the over boost CEL during some runs at Atco this past November. But the CEL does come up when you usually get to the 22+ PSI area.
Old Dec 19, 2009 | 02:34 PM
razormb's Avatar
CLA
Its the Tune. You guys need to go back and talk to Jerry. I used to have the same problem.
Old Dec 21, 2009 | 11:44 PM
GL 350 Bluetec
Here is the response I got from Jerry. He is helpful and knowledgeable. Ill send my ECU back to them when I get a chance.
You are hitting trq limiting. Your ECU will need to be sent in so we can remove the trq limiters.
The blower is cutting out when you hit the upper trq limit. The easy way to check this is to plug in STAR and see if you have a "load limit active" code in the ECU. An OBDII scanner will not pick this up.
Good news is that you are hitting the over 400ftlbs and the tranny doesn't like it.
The bad news is that you have to send in your ECU again so we can remove it.
We don't do it to every ECU because it is something that only WE can do. No other tuners do this.
Old Dec 23, 2009 | 04:37 PM
trbo2nr's Avatar
2004 C32, 2006 Honda CBR1000RR, 2007 Harley NightRod, 2013 Harley Road Glide Custom
EXCELLENT! Thanks all with the responses. I need to send mine back to Jerry- since he did mine too. Who has his current e-mail? I have his card taped to my ECU but think the info is old. I'll dig through my old e-mails in the meantime.
Bob
Old Dec 23, 2009 | 07:37 PM
loudandheard's Avatar
C32/C55 AMG
Did you do a coolant flush when you changed out pump? You could have an obstruction.
Old Dec 25, 2009 | 12:55 AM
francoisisp's Avatar
AMG
im runing NGK plugs and magnecor wires i seem to have his somewhat of a stall after reaching 120+mph momentarily did changing the gap do anything? i changed to IC pump in september and its not the same problep i got when the ic pump was bad any solution ?
Old Dec 25, 2009 | 09:38 AM
320 dreamer's Avatar
2003 porsche 996 turbo
is the 185 the only mod with the tune/ thats way impressive if your bangin 400 ft/lbs with just a tune and 185!!!
Old Dec 25, 2009 | 04:49 PM
60n5pt1's Avatar
2002 C32 1987 190E 2.3 334K miles and going
Yep, happened to me a couple of times, just as I was getting on the freeway and close to 60-65 mph. It's as if the car had a hiccup, drops rpm suddenly and shifts to next higher gear. I thought it was a belt slip. And usually when I first start the day. It eventually went away and hasn't happened
yet again.
Old Dec 25, 2009 | 05:20 PM
TemjinX2's Avatar
i havent tested yet... i blew a gasket or seal a couple of days ago. So i gotta wait till its fixed.
