Why are my shift points so high?
Under 30% acceleration, even in W mode, the car shifts gears at almost 3k RPM. The car is stock. In the service history, the dealer replaced the TCU in '06. Is it possible that they did a poor job, or none at all, of doing the gear adaptation through star?
Here's the interesting thing. While accelerating, I can tap the shifter to the right, while it is in D mode, and I can get the trans to shift where it should be shifting for that much throttle, at about 2100-2500rpm
Super Moderator Alumni
What makes you think 3000k is too high of a shift point? Coming from a sports car background, I find the shift points far too low on the C32. The S/C does not even engage until 2700rpm under light load. Our cars do not have enough low-end torque to merit low shift points, unless you are driving like my grandmother and never top 30mph.
I use the 30 second "ECU reset" regularly, to clear the tranny adaptions and get cleaner, snappier shifts. Search it out in this forum and try it out.
Nothing interesting there. Yes, you can sometimes "encourage" the car to shift earlier with a manual nudge.
I use the 30 second "ECU reset" regularly, to clear the tranny adaptions and get cleaner, snappier ****s. Search it out in this forum and try it out.
This was a relative example, at 40-50%, it revs out to 5,000rpm!
Also I'm curious about getting a STAR adaptation because some of the off throttle downshifts are a little sloppy and then when getting back on the throttle, it's not as smooth as it could be IMO.
MBworld Guru
white and whiter
20-30% throttle? still too much...LOL
I barely use 15-20% in city driving. 17.4mpg avg. yes, I checked with my REV soft.
shift point depends on load as well as speed. that sounds perfectly normal.
Funny story and true: last month, my brother-in-law tells his family that he going to get rid of his Range Rover and buy a Prius. My 15 year old niece says, "Oh dad, you'll need to start wearing your wedding ring or everyone will think you are gay".
He hasn't gotten that Prius yet.
if i'm very very light on the throttle, maybe 5-10%, the car will shift at 2300-2600
