Renntech Camber/Caster kit & Speedy's toe links
Old Dec 22, 2009 | 06:58 PM
AMGSC's Avatar
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
Has anyone tried these? They are listed on Renntech's website at $545 but no pics.
Are they control arms or like the KMac end bushings?
What about the adjustable toe-end links? Code 3's did not fit and were useless but what about SpeedyBenz's?
Old Dec 22, 2009 | 09:24 PM
hooleyboy's Avatar
Former Vendor of MBWorld
C55,SL55,C63
They are not for a C55, Unless some product came out this week that I didnt know about. They are not like kmac
Old Dec 22, 2009 | 09:42 PM
AMGSC's Avatar
I got a set of control arms made by FD about six months ago and I also noticed the difference but I find MbArts at a slightly better price of $310 whereas Vadim charged me $400 a set and told me that was his costs to make them. So I just bought another set off Ebay from MbArts which I will use for even more control. The other three control arms are identical in size and lenght.
I just contacted SpeedyBenz for the Toe-End links as Kleemann recommended them over everybody else and refered numerous other customers to SpeedyBenz. I will be purchasing a set to control the toe.
Finally, I will most likey buy the KMACs to correct the caster which neither the camber arms nor toe-links will address.
Old Dec 22, 2009 | 10:29 PM
hooleyboy's Avatar
C55,SL55,C63
I just did the install of the camber arms. After we for the camber set, We noticed the car was toes in. Rich was able to adjust that too. So I'm not 100% sure you need toe links. You might want to look into it further.
Old Dec 23, 2009 | 03:14 PM
speedybenz's Avatar
AMG C43, 1999
AMGSC, the rear toe on your C55 is adjustable and may fix the problems you are having.
And the Camber arms, toe links and other suspension links for the rear of the car that I make will fit your C55. I make several different sets and types of suspension links.
Jeff
Old Dec 23, 2009 | 04:51 PM
AMGSC's Avatar
Jeff
Payment sent! Thanks Jeff. I hope these coupled with MbArts and FD's camber arms plus KMac's caster kit will give me maximum control on the track and strip.
