FS:Kleemann Twin Screw High Boost Kit
I agree with you. I just don't understand why Brandon and Cory are so conservative. I have a 2.2 litre twin screw. The 65mm pulley made 12psi and my 70mm made 9-10psi without even breathing hard.
A larger crank pulley by only 20mm should have a minimal impact on hp drain according to FD. I've seen Mustangs running Kenne Bells on a 2.2 litre up to 24psi without any problems and making 800rwhp. btw...We all know the Kenne Bell is the same Autorotor but with a different housing.
I asked for a more aggressive tune and he said my tune already have more advanced timing than the 55K S4 tunes.
He told me that ASP does welds the outer ring on the stock pulley and they will fall apart. He also mentioned that ASP does not balance their pullies but did not know if that has changed. Well it has, ten years ago ASP was not as advanced but today they have state of the art equipment and technology.
Regardless, I'm still going to try my 175mm pulley as I still doubt it will create that much more heat. BUT...I could be wrong and if so...I have no choice but to go monster turbos. My 9:1CR has must need boost to survive from this point on.
As long as it says KLEEMANN on your S/C they will always play safe! Trust me, i've been three times to the KLEEMANN headquarter in Denmark and talked to the CEO and Working shop manager, and everytime they told me these "behind the scenes" information
Specially on these "old" M113 engines that have been converted to F/I. They have grown to big now and care more for the newer models.
And with that said, the service i have got from KLEEMANN USA (Cory) is like 1000 times better then from KLEEMANN Denmark, the people in Denmark basically just don't give a f*ck!!
Yes, you have the same S/C as in the Kenne Bell setup, 2,2 L/R and nobody is going to tell me that you can't push that S/C to more then 12 psi
I think KLEEMANN is thinking like this. "Lets just share information if the customer has kept his mods to KLEEMANN stuff, if not we are just going to tell them that it ain't going to work...That way we are safe..."
In your case, running 18 Psi, they think that their Fuel system won't manage to keep up with that much boost contra fuel support. Again, they are thinking WITH stock injectors,stock fuel pump,stock TB and so on and on...
To be honest, KLEEMANN stuff isn't that complicated as they sometimes assume they are. It's basically as top mounted S/C with a IC, a fuel system that rapes the stocj injectors with 8 bars of fuel pressure and working at almost 100%, and a raped signal to the MAF to keep it under the famous 5 volts
If it sounds like i'm disappointed with KLEEMANN, it's becuase I am!! Haha! I'm now working with a vendor that has much more knowledge when it comes to taking my car to another level, just like you are doing with your C55.
Edit: The Kleeemann 6 cylinder blower is 2.0L..The V8 blowers are 2.2L
so in this blurb of theories you gave us, perhaps the kleeman blower is an upgrade over the factory c32 blower?
Only things still not installed are the bigger injectors, fuel pump, 170mm crank pulley and Meth kit.
