C32 Heat Exchanger Options
I'm thinking now would be a good time to upgrade the heat exchanger, and liquid pump on my C32. I wouldn't mind making custom brackets, so I was looking around at other universal heat exchangers. Don't really want to cut up the C32... Does anyone know the max size we can fit in the OE heat exchanger location? The Eurocharged heat exchanger is 32"x6.5"x2.25", and I found another that is 31.5"x9.5"x3.5" for over half the price... Who has best prices on Johnson CM30 right now? Is the CM90 overkill? After switching to such a larger heat exchanger should I still separate it from the engine coolant system? If I were to do so then I would need the PTE thermostat? At the same time I would like to install a co2 spray for the heat exchanger. Probably go the custom route for that. I was reading some threads online, and it isn't all that hard to piece together your own system.
SPONSOR
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Ok, the HE size matters, but the core type matters more. All heat exchangers are not the same.
If you get the CM90 let me know so I can smack you. Its way overkill and will bottleneck the rest of your system.....lol
Seperate engine cooling is a good idea, expecially if tracking your ride.
You don't "need" the PTE, but it is a good idea.
Save your cash on CO2, not worth it. Spend the cash on a NOS 50 shot direct to the throttle body and you will see 8x the cooling effects.
So, who currently offers the best heat exchanger for the c32? People don't really seem to list what type of core is used... Guess I will be saving up for NOS then. It has been on the back of my mind for a while now.
SPONSOR
I like (eurocharged) and ran it among all the others on the forum. The eurocharged ones are built to spec by a high end mfg and not produced in house anymore. Big difference in quality then those imitation ones listed.
2001 C32 AMG
I'd also like to ask this HE question.. Only mods are IC30 & Code3 Pulley and Intake. I've taken the front weather stripping off to get more air into the engine bay (albeit hot air)..
Some days in Ozzie land it gets very, very hot and it's around this time. Unfortunately I won't have the funds to get any HE for a few months so it will really be a project for next summer.. in which case I ask is it really wroth it if I only plan on holding onto the car for a few years and don't really mod it any further? As far as I ready I don't need ti as long as I'm not running a 185 and don't thrash the car around too much on a hot day?
Considering I'm running the stock cooling system with 185MM, and experience no supercharger cut out I think you'll be fine... I'm sure it's hotter in your area, but at most you should only experience less boost. From what I can tell (no IAT monitoring) my IAT hover right below the cut out during WOT runs, and I do experience a cut in timing along with a reduction in max boost. 185MM should run in excess of 22 PSI, and I can only budge 18-19 PSI at most... The Johnson pump alone with 3x flow could very well be all you need for your setup.
1 Post
03 C32 AMG
I'm running the stock heat exchanger with the CM30 pump and 185mm pulley, no problems.
I tried to throw on a eurocharged heat exchanger, but it wouldn't fit under the bumper, and left holes in the bumper support... so much for bolt on!
2001 C32 AMG
Yeah I think the johnson pump helps a lot and ever since I've put that in it's been running so sweet I'm amazed at the difference. If anything I think it might be time being 100k on the dial to do a full coolant flush and refill.
SLK55 AMG, E320 BlueTec, ML350, (formerly) C32 AMG, MR2 Turbo, HD-FLH-FSE, BMW R100RS, Ducati M900
Cooling
I am running the the C3P pulley and intake as my only mods and am looking at the CM30 pump as a replacement for my old OEM. It still works OK but is at an age that most have had them die (60k mi). My understanding was that the CM30 displaced about the same water flow as the OEM as opposed to 3x more? Which is right?
I have tracked my car with the stock pump and after 30min of hard running did experience a drop in performance for about half a lap, but just backed off and cruised for a mile or so and it took off again by the front straight. That was a lot of abuse before heat soak became an issue. However, on that day it was only about 45-55 deg F ambient. Not sure I could expect the same result on a hot July day, lol. Still, if I could get a bit more cooling with just the pump I would like to do so.
Irish
Irish
2003 porsche 996 turbo
the cm30 replacement was due to the failures of the bosch more so than better flowing . i believe the numbers were 3.7 for the cm30 and 3.1 for the bosch. but it lasts longer
for the aussie guys, any cooling mods will b e a great improvement. it will also add to the life of your engine. separting the system helps greatly.
on mine i have supercooler cm30 180 tstat separted system. my temps are in the basement and s/c shutdown is a thing of the past.
2001 C32 AMG
Irish
Irish
C32 '02
there are quite a few options for HE; Yes, the HE from Eurocharged is not exactly a "bolt-on", but it does fit perfectly fine once you measured it right.
IMO the HE is a must have, the recovery time is so much faster, right now the temperature difference is only 11 degrees C, after a long drive, when all parts are up to temperature. The stock HE holds very very little liquid, about 500-700CC, while the EC HE held almost double that amount.
03 g35 coupe...........02 c32 Sold
i have the code3 one. I believe its suppose to a be a spearco core when it was code3. Not sure if it still is. Its bolt on if you don't have the head light washers.
You might want to give them a email. Just be warned, you should ask if they have it in stock because there known to take forever to get parts.
http://www.hpashop.com/product.sc?pr...&categoryId=58
2001 C32 AMG
Brandon also said it has a spearco core at the time, so that sold me as well.
The LET heat exchange you do have to drill it to the crash bar. Its not difficult but something i didn't want to go through.
Either one is fine, I'm happy with my code3 one. Its probably one of the best products brandon ever produced.
I'd recommend the LET one so you dont have to wait weeks for your heat exchanger like i did.
I have a LET 185mm and LET Tune.
