Neat 1/4 mile time calculator based on hp/weight
Old Jan 20, 2010 | 04:13 PM
RLx02's Avatar
C55
Found a neat little calculator.
http://robrobinette.com/et.htm?weigh...66790303569441
I put in 3600 for the weight of the c55 and 315hp to the ground, which is what I dynoed at, and it calculated the quarter mile time of 13.1xx which is what I pulled at the strip. The only discrepancy is that it uses 17% drive train loss, whereas ours is 18% or more...so use your whp if you can.
So, after the kleemann header/ecu install it looks like I'll be running mid 12's!
BTW the car is just about done from the shop, I should be able to pick it up tomorrow!!!
Old Jan 21, 2010 | 12:51 AM
c32used's Avatar
LET C32 2002
Thumbs up
Old Jan 22, 2010 | 06:47 PM
Newzchspy's Avatar
PLAID
If I do mine and extrapolate back with a weight of 3600 for the C32 and a qtr of 12.75, its says I have about 345 HP RW? Can that be correct??
Old Jan 22, 2010 | 08:23 PM
RLx02's Avatar
C55
I think you might have slightly more? Considering they factor in a 17% drivetrain loss whereas our cars, from what i've been told, are about 18%.
Old Jan 23, 2010 | 11:36 AM
blackbenzz's Avatar
haters crazy
That calculator may be a little off. It says I make 568whp lol
Old Jan 24, 2010 | 12:58 AM
hkycoldrct's Avatar
2002 C32 ///AMG
Here is another one based off quarter mile time and trap speed. I used this to figure HP on an old Pontiac I had a 1/4 miles slip from the old Carlsbad track. Pretty accurate.
http://www.boostcontroller.com/display_page.php?i=16
Old Jan 27, 2010 | 11:59 AM
Newzchspy's Avatar
PLAID
Quiet out East there!! We all know what you make, so pipe down
Old Jan 27, 2010 | 12:01 PM
Newzchspy's Avatar
PLAID
Cool, I did that one as well and it says between 343 and 369, so these must be "pretty close."
Glenn
