C55 exhaust mod question
Old Mar 2, 2010 | 02:22 PM
Grey.Spectre's Avatar
2015 E63 S AMG
Hi all... First would just like to say hello to everyone, I'm new here. =) Got my '05 C55 AMG a couple of months ago, and absolutely love it. Its my first Mercedes, and I'm hooked for life. Never will I buy a rice burner again. lol. There's just no comparison.
So I have a question, and I'm sorry in advance if its been answered before. I saw several threads pertaining to it, but none of them cleared it up for me. I'm thinking of taking it in today to get the exhaust modded... What I want to know is, am I okay just cutting out the resonator, or should I remove the secondary cats as well? Seems everyone who's done it on here has done both. I'm just afraid to get rid of the cats in case it won't pass emissions down the line without them. But if I just take out the resonator, will there be a noticeable sound and/or HP increase? Or must the cats come off in order to get any gains? Also, will taking them off cause any issues? And finally, has anyone taken them off and then passed emissions without any problems?
Would appreciate anyone's input. =) Thanks.
Old Mar 2, 2010 | 02:32 PM
jturkel's Avatar
02 C32 AMG
congrats on the new car! and welcome to the forum!
resonator delete on the C55 is good for sound and will NOT affect emissions. However, there is no power to be gained by deleted this. If you delete the secondary cats, you should see somewhere between a 7-10whp gain and more sound. The secondary cats are NOT monitored by any O2 sensors so there would be any check engine lights (CELs) or any problems. Regarding passing emissions, I suppose it depends on where you live. You should be able to pass a smog test, but if you are in CA and they have visual tests, you MIGHT not pass that. I have read on this forum that an SL55 with deleted resonator, secondary cats, and headers passed emissions in CA...but again, it probably depends on the place you go to. If you aren't in CA, it shouldnt be a problem.
Hope the helps!
Old Mar 2, 2010 | 03:33 PM
thegreatfnr's Avatar
05 C55 AMG
Welcome. I had the same concerns as you did initially and only deleted my resonator first. This made it sound a small amount better but nothing too drastic and no real power gain on the good ol butt dyno. A few months later I went back and had the secondaries chopped out and what a difference it makes. The car now sounds like a completely different animal and I felt a small gain.
The only thing at that point that had me worried was the visual emission inspection in GA. They pulled the mirror out and looked under the car and passed it with no questions asked. I figure since the primaries were still in place they didn't care.
Old Mar 2, 2010 | 03:37 PM
02C32guy's Avatar
2005 E55
In addition to what Josh said above, I've gotten the impression from threads on here that the resonator delete gives you a deeper tone and a little more volume while the deleted secondaries effects volume more. I don't think I have heard anyone complain in either case or with both.
Old Mar 2, 2010 | 05:16 PM
jturkel's Avatar
02 C32 AMG
ahh...cant believe i didnt mention this. yes, i think that sounds right. resonator delete results in a deeper tone while the secondary adds volume. i've certainly read that on hear many times. great memory/point!
Old Mar 2, 2010 | 06:09 PM
AMS Performance's Avatar
Former Vendor of MBWorld
AMG
If you plan on doing headers & high flow cats, you may want to keep the resonator in place until the end.
High flow 2nd cats made 10HP/12TQ @ wheels on dyno dynamics dyno (delete makes 13HP/19TQ also @ wheels on DD dyno). Its a great modification to do and is simple & cost effective. If you want a smoother more european tone, go with high flow cats. If you want more of an unrefined muscle car sound then go with 2nd cat delete. There is no real reason to even touch the resonator (especially if you are going to delete 2nd cats, you will want it in place to help smoothen out the tone a bit).
If you plan to do headers, then just do high flow 2nd cats and keep stock resonator in place until the very end. Also remember that any time you do exhaust changes it can take a 2-3 weeks for the full sound transformation to occur (sometimes even longer). If you are going to upgrade sound, you might as well upgrade for power at the same time, just a suggestion...
Hope that helps,
~AMS~
Old Mar 2, 2010 | 06:37 PM
spr's Avatar
spr
Well you'd want to dump the resonator if you're doing true duals with an x pipe -
RLx02's Avatar
C55
For sound clips here's all 3 stage of exhaust mods excluding stock.
1) Deleted resonator
http://www.youtube.com/watch?v=3Sw5ZCzExvg
2) Deleted resonator + cats
http://www.youtube.com/watch?v=C1uxDOef3vY
3) kleemann headers + straight pipe + resonator + cats (on the dyno)
http://www.youtube.com/watch?v=MDzTW9ijRA4
Old Mar 2, 2010 | 08:55 PM
F1Bobby's Avatar
From: People's Republic of California (Southern Region)
C55 AMG, CLK550
Very nice!
Old Mar 2, 2010 | 09:06 PM
05 C55 AMG
I dont think I agree with this. It is very cheap to cut the secondary cats and resonator to get a great sound and pick up HP. I decided to go ahead and chop em both out, then if and when I decide to go with headers and then feel its too loud I can add a new resonator at that point. Magnaflow and other companies make various mufflers for cheap or just save your original and have it refitted when/if needed.
Old Mar 3, 2010 | 01:09 AM
RLx02's Avatar
C55
If i had bought my car new and knew how loud it was going to be I would have left the resonator in place but got rid of all cats.
The video does not justify HOW LOUD the exhaust really is...you can hear my car from about 4 blocks away at WOT.
Old Apr 22, 2010 | 08:56 PM
duke444's Avatar
1988 300e, 2005 c55 amg
was searching and found this thread. Just had a question about the cabin noise after you get the delete.. is it loud and noticeable inside when cruising on the freeway?
Old Apr 22, 2010 | 10:26 PM
AMG
Which delete are you talking about, 2nd cats or resonator. Resonator delete pics up no power, 2nd cats does.
The best sound combo is headers & high flow cats, keep stock resonator in place & stock muffler. Its the only real streetable combo, if you start deleting resonators and etc the drone and sound can become too much in conjunction w/ headers & cats. Remember its a mercedes, not a mustang (no offense to any mustang owners)... keep it refined
Old Apr 22, 2010 | 10:34 PM
duke444's Avatar
i understand what your saying and i defiantly want to stick with the mercedes sound. So i think I am going to start looking into where I can get this done. Thanks for the info!
