What size are the lug bolts on our cars?
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWNX:IT
Stock size is M12x1.5, with a 39-40mm shank. This is assuming that the depth of your wheel hub mounting surface is also the same as stock (I think this is normally a standard size, which is 10mm).
If you're planning to run a 10mm spacer, everything will be the same except you need a 49mm shank length.
Most aftermarket wheels are cone seat, and the shank length will vary according to how the wheel is manufactured.
