Bad Dyno Experience
Every thing was good and I turned out to be the last person they dynoed. They did a porsche gt2, targa, various supras, and various other cars.
Since I was the last person I decided to run some errands and what not. I let the car sit for a good hour before I got on the dyno, but the supercharger was still kind of hot. No big deal, I just wanted to get an idea what the car would do with the new pulley, no tune. I had made 282 on mustang dyno a few months back.
So I put it in dyno mode and did the tranny reset. Will once they get it on and strap it down they go for it and I you could see the car struggling. They tell me that the traction control is still on and that I have not taken it off, but you could see all the warnings on the screen for abs and etc off. So they try it again and they are saying the rear brakes are stuck. They keep blaming it on the traction control. By this time the whole place stunk of burnt brakes. They finally look at the straps and they notice that one of the straps was strapped to the brake line, which was causing the brakes to engage.
So they do another run, mind you this is like the 4th or 5th try and the car comes out with 259 whp. I told the guy that this can't be because I had dynoed it before and I had 282 stock and now have a pulley and new HE. I know the HE doesn't make any hp, but I figured the new pulley would make a bit more. The guy had the nerve to tell me that the other dyno run was messed with to give me higher numbers, but the numbers seem right for stock at 282.
On my last pull I only made 264whp and 272 wtq. I'm figuring that the car was extremely heat soaked and that was one of the reason for my low results.
Does any one know of any thing I can do to check on my rear brakes, they seem to be fine, but they still have that burnt smell. I did feel like the rear brake was still engaged for a second, but it seems to be fine. What should I check and do you think there is any thing potentially wrong with my rear brakes?
I'll post some pics later.
worse case-you needs rear lines and pads-
sorry to hear about a crappy experiance!
Les
Les
Mike
Les
I signed a waiver that states that they would not be liable for any damages on my vehicle if any thing were to happen to while in their possession. So I'm pretty sure I do not have any recourse, I was just really disappointed that I wasted my money.
I had done a baseline dyno in the past to see how my engine compared to stock in the past. I wanted to see if the addition of the renntech pulley would make any difference. I know on my butt dyno my car seems to have a bit more get up an go, I just wanted to see actual numbers. I figured that I should have been in the 290+ range with the pulley since I dynoed at 282 with out the pulley.
Les
Les
I really thought nothing of it, I figured if they could do a gt2, they could do my car with out a problem. I will check from now on.
