Shifting from 1st to 2nd gear
Old Apr 4, 2010 | 05:03 PM
Robert AMG's Avatar
Cls63 & C32
When the car shift from 1st to 2nd gear on full throttle it shifts at 5500-5700rpm specially when there is spin, every 4 to 5 runs only one get to 6000 rpm, it makes me angry specially when racing with another car, is there any way to make it shift at redline from 1st to 2nd gear? all other gears are fine.
Old Apr 4, 2010 | 09:05 PM
gt4awd's Avatar
2005 Pontiac GTO 6.0 LS2 - Blue
If you have it in the manual mode it should hold shift until redline.
Old Apr 5, 2010 | 06:50 AM
Robert AMG's Avatar
Cls63 & C32
I don't have manual mode, my paddle shifts work with S and C.
Old Apr 5, 2010 | 11:59 AM
mikekuriger's Avatar
2010 C63
you will run the 1/4 faster if you shift at 5500
Old Apr 5, 2010 | 12:55 PM
Robert AMG's Avatar
Cls63 & C32
but can you explain more how i will run faster 1/4 mile!!!
Old Apr 5, 2010 | 02:04 PM
2010 C63
peak torque is 4300-4400 rpm, and you want your shifts to put you a few hundered rpm before peak torque so acceleration is maximized. engine loses torque over 5500 rpm.
Old Apr 5, 2010 | 02:11 PM
Robert AMG's Avatar
Cls63 & C32
For 1/4 mile you need hp much more than torque.
Old Apr 5, 2010 | 04:21 PM
2010 C63
well, if you're interested in breaking out of the 13's stock, I have told you my secret. You're free to use the information or not.
~mike~
Old Apr 6, 2010 | 02:09 AM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Your “stock” C55 runs 12's and walks E92 M3s?
Me thinks you’ve a ringer.
Old Apr 6, 2010 | 02:23 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
hmmm i heard of some sti owners doing this since the turbo runs out of power in the top end.
I know my friend did it in his sti and the car seemed to pull harder but i don't know if it was actually faster.
I think it would be interesting if someone ran at quarter both ways.
Old Apr 6, 2010 | 04:49 AM
SGTzAMG's Avatar
Veteran: Army
02 C32 AMG, 05 SL55 AMG, 09 SL63 AMG, 14 E350, '18 G550, 92 300ZX & 15' GL63 AMG
do u manually shift it yourself?
u do know if you put the gear selector all the way to 1st gear, the car will automatically shift itself to the perfect shift point? if your on full WOT, and u leave it in 1st gear, you dont need to shift to 2nd manually, the car will do it for u. u should try it
Old Apr 6, 2010 | 05:22 AM
RLx02's Avatar
C55
I dunno about you guys but i think a handful of engineers at mercedes know a little more about the shift points than we do.
Old Apr 6, 2010 | 11:52 AM
ali saklaoui's Avatar
C32AMG.335 e92 fbo.protomotive996 gt2
+1
Old Apr 6, 2010 | 01:53 PM
2010 C63
If this were always the case, there would be no need for "tunes" or "chips". Revving the motor to redline is usually not the quickest way down the 1/4 mile. between 5500 and 6500 rpm the engine is screaming away, making lots of noise, but not accellerating the car as quickly as it could be. This is just my observation and I'm in no way going to argue with all the experts on this forum. However, I suggest that instead of making statements based on your opinion of what "should" be faster you might want to test it for yourself. When I tune my cars, I always set my shift points so that the car stays within the max tourge for the longest time period possible. If your engine has cams or big valves or ported heads or some other mod that allows it make more torque at 6000+ rpm, then yes by all means that would be the better shift point.
Old Apr 6, 2010 | 03:26 PM
Robert AMG's Avatar
Cls63 & C32
I do it always like you said, i leave the gear selector at 1st gear and let it shift itself, and it shift at 5500-5700.
Old Apr 6, 2010 | 05:04 PM
When you shift at 5500,your rpm will drop below 4500 and will loose torque but if you shift at 6000rpm you will conserve more torque for the second gear.
Old Apr 6, 2010 | 11:12 PM
TemjinX2's Avatar
is your car in C mode or something? My car shifts at 6200rpm if i go WOT in just auto mode.
Old Apr 7, 2010 | 05:11 PM
gt4awd's Avatar
Don't you have LET tune? I know when stock my c32 liked to shift a little early, but after 185MM, and tune it seems to hold until 6.2k RPM.
Old Apr 7, 2010 | 09:59 PM
TemjinX2's Avatar
it did the same thing when i had the power chip tune. I'm pretty sure it did it when i was stock too...the stock redline is suppose to be 6200rpm..
Old Apr 8, 2010 | 12:08 AM
gt4awd's Avatar
Maybe his gas peddle isn't registering as WOT? I don't know, but I do remember it shifting a little early at times when stock.
Old Apr 8, 2010 | 12:13 AM
TemjinX2's Avatar
are you sure its in sports mode?
Old Apr 8, 2010 | 12:17 AM
gt4awd's Avatar
No, right now it's in POS mode, but yes back then it was in Sport...
Old Apr 8, 2010 | 12:22 AM
TemjinX2's Avatar
lol...maybe try it when your a complete stop. if not, maybe you need to have your tcu reprogrammed.
