Jack stand point for C55
I did the search but nothing came up specific. I usually use a lift at a shop or floor jack at home to work on the car, however I will need to put the car on 4 jack stands. Does anyone know which safe point to put the car on jack stand?
I would assume that the stock square jack points are a good spot. As for the front, I also put it on the cast steel axle beam before the bends on the end (this is where the front center jack pad is located as well). As for the rear, I haven't been back there yet to look where would be a good place, listening.....
