Rain Sensor Voodoo
Old May 31, 2010 | 07:39 PM
northyork's Avatar
2006 C55 AMG
Rain Sensor Voodoo
When I have my wipers turned on auto, the sensor seems to have a mind of its own. It will just randomly wipe when there isn't a hint of rain.
Is there something I need to adjust? Or clean?
Thanks...
Old May 31, 2010 | 08:42 PM
duke444's Avatar
1988 300e, 2005 c55 amg
maybe i am wrong. but i think the auto feature is more for when it rains hard then light then hard then light and the wiper speed adjusts automatically according to the rain.
i don't leave it on auto all the time.
Old May 31, 2010 | 09:01 PM
02C32guy's Avatar
2005 E55
If it is doing that excessively, there might be an issue with the sensor. Otherwise, It's normal.
Old Jun 1, 2010 | 03:25 PM
King320's Avatar
03 C32 AMG
is the setting for auto twisting the stalk one click toward yourself? Not sure if mine has a rain sensor or not. How can i tell?
Old Jun 1, 2010 | 04:08 PM
02C32guy's Avatar
2005 E55
It's one click away from you. I believe it has a picture of one line. Also, you can look and see if you have the sensor behind you rear view mirror. Or you can check your vin for free here: http://old.mbclub.ru/mb/vin/?lng=eng
Old Jun 1, 2010 | 04:32 PM
chris.bachman's Avatar
a car.
I have a rain sensor, I've checked both visually and with my VIN. However when I turn the wiper position to I for auto-sensing it just goes off at set intervals, not intermittently according to the amount of rain. The windshield was never replaced which I've heard could be a cause. Anyone have an estimate on what the repair for that sensor/module is?
Old Jun 1, 2010 | 06:09 PM
masterianvii's Avatar
LADA 1600
Have the same exact issue, it happens once in a while, and it should be expected given how they work.
They work by examining the visual clarity of the windshield, by shining some infra red light at an angle. See this article: http://auto.howstuffworks.com/wiper4.htm
I think it's fairly easy to trick the system into thinking it's raining if something happens to distort the light. Dirt, overpasses, trees, who knows. The system is obviously smart enough not to do it all the time, but it definitely isn't perfect, so once in a while it happens.
As mentioned above, if it's happening constantly, make sure your windshield is really clean, or the sensor is not busted. Otherwise consider it normal .
Old Jun 1, 2010 | 11:06 PM
mkonei's Avatar
05 C55
mines never worked in the way i thought it would, i just dont bother it. i need a new windshield, and was considering getting one without the sensor, and saving 200. not sure what would happen without it hooked up though
