No Start after replacing dead battery
Old Jul 27, 2010 | 10:44 AM
03e55's Avatar
03' E55
This is on my brother's 02' C32 he just bought. He let the car sit a day and a half and the battery went dead. Replaced bad battery with new one drove car 4 days just fine and he let it sit one day and it is dead again and killed the new battery.
Last night we exchanged the battery for another new one and I did a battery parasitic load test on the car it seems to be fine when I connect the meter it pulls 2 amps for 30 sec. and gradually drops down to 0.107-0.120 amperes after a total of about 1 minute 30 sec. We tried pulling fuses and none resulted in more than a .100 amp drop when it was pulling 2.0 amps.
I reconnected the battery and now the car turns over but will not catch it.
It started to go the very first time I turned it over but now it just cranks.
What is the likely culprit here or what could have been fried form having the battery die several times?
Old Jul 27, 2010 | 11:14 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
might be a bad cps sensor, spark plugs or fuel pump if its cranking but not catching.
Old Jul 27, 2010 | 11:25 AM
Gramma_Benz's Avatar
2002 C32, 2012 S550
Make sure you pull each seat module fuse....
Sounds like this to me:
https://mbworld.org/forums/c-class-w203/262131-temjinx2s-20-seat-control-battery-drain-fix.html#post3068555
Old Jul 27, 2010 | 11:54 AM
moosejaw's Avatar
none
Originally Posted by Gramma_Benz
Greg post is dead
Old Jul 27, 2010 | 02:23 PM
02C32guy's Avatar
2005 E55
If you tried jump starting the dead battery, you may have burned up the rear sam. Inspect the rear sam for any evidence of this. It may show up in form of a discoloration around where one of the fuses is inserted.
Old Jul 28, 2010 | 04:28 PM
03e55's Avatar
03' E55
Gonna check some stuff tonight and see what we have and report back. Which fuses go the seat contollers just 1 and 2 or do I pull 21,22,27,38 also?
Old Jul 28, 2010 | 04:37 PM
loudandheard's Avatar
C32/C55 AMG
it's best to physically unplug each module, which are located under each front seat.
Old Jul 28, 2010 | 04:43 PM
03e55's Avatar
03' E55
Can you explain a rear sam, I assume it is an abbreviation I have seen it on here before.
Old Jul 28, 2010 | 04:46 PM
03e55's Avatar
03' E55
He didn't try to jump it but he did have the battery hooked with about 4 volts showing and was trying to charge it also hooked up, before I got a chance to look it.
Old Jul 28, 2010 | 04:49 PM
02C32guy's Avatar
2005 E55
Rear Signal Acquisition Module. Fancy name for the fuse box in the trunk.
Old Jul 29, 2010 | 09:44 AM
03e55's Avatar
03' E55
That is fancy
We figured it out no problem. When we were testing for a load we tried all the fuses and my brother put the fuel pump fuse back in the wrong slot.
So all is well for now. I had him leave everything connected and will test for a load when the battery dips again. I want to be sure it is the seats and not the overhead or sunroof since the sunroof switch half works.
Thanks to all,
