cheapest place to buy door lock/actuator assembly?
C32/C55 AMG
Parts.com and check out the diy I made. Parts.com has the best prices and the actual parts come from MB delaerships. They are oem mercedes parts. I would also send them an email to assure that your are getting the correct side actuator. I think there is a difference between left and right, but I could be mistaken. I am sure that the driver's door assembly is different from all the rest of them. Take in mind that the driver's side door will not lock unless locked manually from the out side of the car or with the alarm. I had every thing all put together and I thought that my driver's side went out, but it's just one of MB's idiot proof mechanism from locking yourself out of your car.
https://mbworld.org/forums/c32-amg-c...l-removal.html
C32/C55 AMG
Look here is a diagram for it from parts.com, more than likely you need the left one, but send parts.com an email to find out. Again these are genuine mercedes parts from dealerships across the country. You can't find a better deal and it's all brand new parts directly from mercedes.
It's part #6 in the diagram.
http://www.parts.com/oemcatalog/inde...layCatalogid=0
that was actually the wrong part
correct part is here: http://www.parts.com/shoppingcart/in...05&catalogid=1
part number is 2037200135 for left driver's side door lock
C32/C55 AMG
From some research I was doing few months back people came to the conclusion the problem is a small spring in the actuator that snaps. You can buy a set of springs at Autozone for $5 dollars, do a little modification, and fix the $100 dollar actuator.
i called a couple independent shops and got some pricey quotes. one for $450 w/ my part and $610 if they get the part. another for $500 w/ my part and $700 if they get the part!
02 c32 amg 94 3000gt vr4
its not that bad. a decent weekend mechanic with a set of torx, rivet gun, and some good metal drill bits should be able to handle it...may wanna get some new door panel clips as these sometimes break depending on how old they are. they are only a few cents each
Super Moderator
Have a reasonably well equipped workshop. Most drivetrain and chassis work is duck soup.
Dicking around with MB’s nightmarish electronics is beyond my comfort zone.
“Man’s got to know his limitations.” - Harry Callahan
C32/C55 AMG
Check out my thread, I did the job, but there were a lot of unknown factors and I did not always have the right tools, so it took longer than it should. Had I had all the right tools and new some of the quarks of the job it would have been much easier.
Take in mind I have done it myself.
I would say that I wasted a few hours figuring out stupid things. If you remove the door handle, it makes the job much easier, but then I didn't have the right tool to remove the door handle. I had a torx set, but it would not reach the bolt. Then there is a tough piece of plastic/styrofoam wedge that supports the assembly and I didn't know that it comes out in two pieces. I was using the rivet gun incorrectly and there was more time wasted.
Putting every thing back together was a piece of cake, it was just figuring every thing out from vague instructions and not having the right tools that made the job more difficult. I'm sure if you've done simple jobs on your car, you should be more than capable, just make sure that you do the job when you have time and definitely have another car available if you need to go buy a tool or what not.
My neigbor works at a body shop that works on exotic cars
he noticed my door lock acting funny and asked if i wanted it fix
i said yes and he offered to fix it for free
He had a brand new part sitting at work not being used
So he and I did it together.
He knew exactly what to do and it didn't cost me anything.
C32/C55 AMG
