Quote:
-;-ZAYED-;-
one pieceOriginally Posted by cm60k
do you want to install "E55K" 8-pot calipers with 1-piece or 2-piece Rotors..??-;-ZAYED-;-
You can go with 1-piece (360X36) Rotors from "W218 CLS550",
just need to put (6.5mm) washers between caliper bracket & knuckle, to spaced a caliper for proper pads balance in the middle of the Rotor,,
otherwise, will need to go with custom Rotor with lower Rotor hat..
-;-ZAYED-;-
-;-ZAYED-;-
-;-ZAYED-;-
Ok thank you very much.Originally Posted by cm60k
You can go with 1-piece (360X36) Rotors from "W218 CLS550",just need to put (6.5mm) washers between caliper bracket & knuckle, to spaced a caliper for proper pads balance in the middle of the Rotor,,
-;-ZAYED-;-
Quote:
Those Rimes really nice on W203..Originally Posted by WaveyKat
are they comes as optional 18" or 19"..??
-;-ZAYED-;-
yes they are Forgester F14 Wheels comes in all Different Sizes..
Excellent, Thanks..
-;-ZAYED-;-
-;-ZAYED-;-
