long awaited differential cooling fin adapter is here!!
Old Sep 29, 2012 | 07:24 PM
betrezra's Avatar
C63 507 AMG DA Car #19
2m. - I'll see about getting one fabbed up .
Old Sep 29, 2012 | 07:45 PM
loudandheard's Avatar
C32/C55 AMG
I got the kit from frank a long time ago and never installed it because I didn't have the right tool. You're welcome to take a look at it.
Old Sep 29, 2012 | 08:16 PM
betrezra's Avatar
Loud- I'd like to borrow and knock out a copy. I'm happy to help install yours.
Old Sep 29, 2012 | 08:54 PM
C32/C55 AMG
Sounds good, let me know when you want to borrow it.
Old Sep 29, 2012 | 09:09 PM
2MCHCAR's Avatar
Supercharged CLK500,ML500,S580
If you guys make copies, can you fab one up for me? I'll gladly pay for your time and materials if you can make this happen; PM me the details!
BTW, the kit loud has also comes with new bolts so if you can get their measurements as well it will come in handy when it comes time to install our diff fins.
Old Sep 29, 2012 | 09:34 PM
betrezra's Avatar
2m. That is the plan!
Loud----- thanks for the help.
Old Oct 1, 2012 | 04:43 PM
  #32
cm60k's Avatar
Zayed,
From my quick research on this board and the Mopar board to retro-fit either of those to your benz you will need an aluminum adapter.
There are a few possibilities dep on your cars setup:
1. If you are super lucky you could have a factory diff cover that will allow you to simply bolt this cooler on. Unlikely.
1a - or next time you service the rear end..... add a rear diff cover that is made for this cooler.....check it below:https://mbworld.org/forums/5368587-post4.html
I understand there is quite a bit of work involved in removing the rear diff cover.... so not a drive-way job.
If I get a new rear end with higher gears..... I'll got this route..... for now I'll make a custom adapter plate.
2. You may also have a diff cover with pre-existing cooling fins built into the cover..... which will most likely not allow you to adapt this bolt-on cooler.
3. If you have a smooth diff cover.. .my clk55 has the smooth cover... you will bascially be installing an adapter bracket to the bottom two diff cover bolts, then bolt the cooler to the adapter bracket. The adapter appears to be l-shaped.
I went ahead and ordered the stock C55 bolt-on AMG diff cooler. When it gets here, I'll look at fabricating a simple l-bracket to mount this to my clk55 diff cover.
Hope this helps.
Thankss a lot Jeff,,
Unfortunately, there’s no direct bolt-on cover for my diff. in the dealer,, i have an old style one,,
I well try to customizing one (hope i can)....,,
*See the attach, what’s my diff. cover look like.....
long awaited differential cooling fin adapter is here!!-picture-239.jpglong awaited differential cooling fin adapter is here!!-picture-244.jpg
ZAYED,,
Old Oct 1, 2012 | 05:58 PM
  #33
C_DirtyTwo's Avatar
a land yacht.
Frank is there any way you could order some more of those adapter kits? I need one!!!!
Old Oct 1, 2012 | 06:29 PM
  #34
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
it was a one time thing. i had to get my relative to get them and ship them. too much hassle to bother them again.
i have to search and look up the info for the guy who makes these again. completely forgot about them.
Old Oct 1, 2012 | 06:59 PM
  #35
betrezra's Avatar
Frank - if you come up with a contact... I bet we can come up with about 10 people wanting a COOL REAR_END
Old Oct 1, 2012 | 07:58 PM
  #36
xxaarraa's Avatar
Multiple
Originally Posted by xxaarraa
hmm, my C55 already has this? Did the 55s get it from factory? It took me a while to figure out what the heck it was lol
Anyone know?
Old Oct 1, 2012 | 08:18 PM
  #37
betrezra's Avatar
CM- You should be able to have a custom aluminum adapater made for your diff cover.
It's a pretty simple concept...... basically bolt a solid aluminum adapter to 2 of the diff cover bolts and bolt the heatsink to the adapter. Ideally more contact area between the diff cover and adapater and heatsink the better for good heat transfer from the diff to the fins on the heatsink.
GL>
Old Oct 2, 2012 | 07:27 PM
  #38
C_DirtyTwo's Avatar
a land yacht.
Anyone know?
yeah c55's come stock with them.
Old Oct 3, 2012 | 07:28 PM
  #39
xxaarraa's Avatar
Multiple
Thanks man.
Old Oct 3, 2012 | 08:30 PM
  #40
betrezra's Avatar
My c55 cooler heat sink arrived today...... Pretty! I might do the polish job to it with my air tools.
Old Oct 3, 2012 | 10:53 PM
  #41
PC Valkyrie's Avatar
C55 AMG, 135i, 911 GT3, GLE43 AMG
I must admit that I'm surprised so many members here want to add this modification.
Yes, this differential cooler is one of several "upgrades" that the W203 C55 got to make the car a better on-track performer compared to the previous C32 (and 2003-2004 CLK55).
I could be wrong, but I don't get a sense that many members here take their cars to the track for lapping days where the car is subjected to continous high speed running for prolonged periods, where this differential cooler MAY be of potential benefit.
I just don't see this modification as very necessary if the car is not used for lapping on a track. If the motivation is to get it for looks, it certainly doesn't stand out unless you look under the car.
Old Oct 4, 2012 | 09:41 PM
  #42
C32/C55 AMG
Here are pics from when I attempted to install the kit. Lucky I didn't have the tool, other wise it would be installed.
When I did the rear differential oil change. Requires triple squares
Old Oct 4, 2012 | 10:20 PM
  #43
betrezra's Avatar
Loud. Lmk when I can borrow this part. I'll visit a fab shop soon for reproduction.
PC-everyone likes a cool rear end)
Old Oct 4, 2012 | 11:19 PM
  #44
C32/C55 AMG
I can try to drop it off on the 12th. I have a cpa exam at noon and should be done by 3 or 4pm. We can figure out something then.
Old Oct 5, 2012 | 05:42 AM
  #45
betrezra's Avatar
No rush. My car is in paint. Jeff
Old Oct 5, 2012 | 08:47 AM
  #46
C32/C55 AMG
Can't wait to see how the magno silver comes out.
Old Oct 5, 2012 | 11:30 AM
  #47
cm60k's Avatar
Hey Loud, Thankss for the Pics...,,
Is this the same Franks Adapter.....??
ZAYED,,
Old Oct 5, 2012 | 02:08 PM
  #48
C32/C55 AMG
ZAYED,,
Yes, I got it from Frank.
Old Oct 5, 2012 | 03:27 PM
  #49
C_DirtyTwo's Avatar
a land yacht.
could you let me know the price? I'd like to have a copy of it as well if possible!
Old Oct 5, 2012 | 05:11 PM
  #50
betrezra's Avatar
Yes I'll get a quote on a batch.
