C32 Amg 181 Pulley + EC Tune ??
C32, 911 SC
I also went with the really fine mesh. I did four layers (from inside-out, fine mesh, filter, fine mesh, and another filter) instead of the suggested two layers, which might be an overkill
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
The rubber weather stripping is that long rubber strips on the top of your engine that prevents rain from coming in (I usually put it back on when it rains
)[/QUOTE]
Don't you mean at the top edge of the firewall??
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
#36
Mercedes C32 AMG
I have now ordered one Heat exchanger as you guys recommended me to ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Do i need to remove the front bumper to install it? Do someone have an DIY on it?
Thanks!
Thanks!
#38
#39
And make sure you bleed the system really well or air pockets will cause your engine to overheat.
