Driver's side butt warmer not working, but not draining battery?
Solution is replacement of element, which requires removing some of the seat upholstery. Probably not a DIY job.
Mine was replaced under warranty, and then failed again about a year later (out of warranty). I did not replace it again, as I already have a hot a**.
and that the heater is not broken. Oh well..... That butt heater is fairly new and it is kinda weird that it failed like that. I think that the reason those fail is that the cushion between the heather and the leather on the seat is very thin and if you are around 200lbs like me, it tends to fail when you sit on it every day. I am still hoping it is working and maybe it will fix itself
. If anybody else has had the same problem and replaced the heater, what is the cheapest route, and how did you do it?
There is an aftermarket option.. I think... You'll have to do some search on that..
. We need to find which fuse controls the heated seats and try to replace it to see if it fixes the problem. That is the easiest and cheapest route to go at this moment. BTW dlwiser, how long have you had the same problem?
.Bryan
+1
