What would cause an exhaust valve to break???
2002 c32 amg
As you know I rebuilt my engine due to an exhaust valve breaking, causing the piston to shatter and spitting the chucks out the back of the block. I rebuilt it and put it back in the car. upon restart it started fine, then died. I ended up pulling the passenger head off again and found another broken valve!! This time in cylinder #1. what could be the cause of this? Any help is great.
C32/C55 AMG
I was thinking cams as well, I started a thread recently and I think as 2002 vehicles we are going to have problems.
https://mbworld.org/forums/c32-amg-c...2002-c32s.html
Here's a video on why exhaust valves break in aircraft engines, I'm not sure if it would apply, but good info none the less.
http://www.youtube.com/watch?v=S0Vo53UVInk
2002 c32 amg
The cams appear to be in good shape. I have two sets of cams and rocker arms and they both appear to be in good shape, and not bent. Does anyone have access to oe specs so I can check them again. There was the one broken one and the other two were bent very bad. I ordered 3 new ones and am going to replace them and give it another run. If this fails I am at a loss of what to do next.
2002 C32 AMG
There is a Tread About the Cams somewhere on the forums, you might want to check out.
2002 C32 AMG
