R&D #7 - POWERCHIPS software
Here is before and after with POWERCHIPS software. 12HP and 25 ft.lbs. of TQ. This is on CA 91 gas, as you can see from the TQ curve at 4400 rpm DME pulls out timing as we reach the limits of 91 CA gas.
With couple of gallons of 104 UL, giving us 93 total, we made as much as 325HP at the top. This file will be used for states where 93 is available.
I am very impressed with POWERCHIPS abilities, we basically created a new file from scratch. US C32 software is significantly more complex than European or Australian versions. We were able to emulate on the dyno and locate timing, fueling and TQ limiting maps. It pretty much took all day on Wednesday to get the file broken down.
Next step will be driving around and playing with part throttle and throttle by wire maps. Which will be done next week.
We are going to spend couple of weeks of further testing on the track and on the street. Final version will be available mid-May.
Graph above is our C32 before and after our upgrades. 48HP and 50 ft.lbs. of TQ. on CA cars and 57HP and 50 ft.lbs. on 93 octane cars.
ODPS, headers and software.
NEXT: Intake manifold and off-road H-pipe. I should have the results shortly.
Thank you for listening.
Vadim, could you be more specific for my personal case. Will the software that Evosport/Powerchips will produce be compatible for my car ? Reason I am asking is because you mention that the stock US software seems to be different from the European version.
My second questions is >
Did you manage to squeese out the extra HP due to fine tuning of the stock software alone or is it an effort to fine tune the stock software to take into account the ODPS + headers kit ??
Thx for you answer.
:p :p
98 octane DIn=93 octane US standards ?
Bart, actually it iwll be easier to make power on your car, since you are in Europe. Powerchips has files for Euro DMEs, we will just have to modified them with the same data as US.
This program is setup to work with ODPS and headers. We will have different versions tuned to a particular level of parts. In other words, Stage I, Stage II and so on.
98 Euro is 93 US.
In many years of tuning cars I very rarely find significant software gains on stock cars. In most cases when airflow is improved, i.e. more boost, better exhaust - the software tuning can offer significant gains, like in this case.
Jerry, send me an email, I wanted to finish our conversation from before.
Marc
Pocholin: Thanks! More stuff is on the way.
however,
RENNtech Kit 2 (ECU Performance Upgrade +
& Larger Crankshaft Pulley Kit) is doing 45hp and 60 Lbs.-Ft. for $ 3,495 ...
the question rises now guys, How much will be the EVO kit (headers, Pulleys, and ECU) will cost?
Nice numbers Vadim!
however,
1. Make them all lighter, and thus easier on the engine to spin=more power.
2. Our ODPS does not overdrive the engine's accessories like the others which simply change the size of the crank pulley by adding a ring. Thus, the accessories should have a longer lifespan.
3. We include an intercooler reservoir upgrade that adds 6 liters of cooling capacity to the stock system.
Also, these numbers are on 91 octane. Customers with access to better gas will get better results. Take Bverotti for example, who has 98 octane. With only our ODPS and airfilters, has has seen 45hp gained at the wheels.
Pricing will be finalized shortly, but as I mentioned earlier, it will be significantly cheaper than what other companies charge to achieve these gains...and we don't have to go into the engine to get it!
Thanks,
Ben
Marc: Yes, we can remove top speed limiter. Stock it is suppose to be 155 mph. Mine for some reason did not cut in until 162 mph. C32 is gear limited to 178 mph with stock tires. Putting a set of 19's will put you over 180mph. I believe C32 and SLK32 share the same drivetrain gear ratios, so they should be the same.
Marc
Could it be your wheels? Even a slightly larger rolling circumference would cause a higher top speed (if my logic is correct). I'm guessing the computer cuts in judging by RPM and not by what has been indicated by the speedo. My basis for the argument? Most cars seem to cut in at 157.
What do you think?
As for my car is totally stock except for the Evosport ODPS kit and sport filters.
Thanks,
Ben [/B][/QUOTE]
Thanks!,
Ben
Greetings,
Can you please install a new chip for me, and remove the limiter? I already have an appointment. Any news on the headers?
Thanks and
GOD BLESS AMERICA,
Daniel
Email me with a number I can contact you at, and I will arrange to have both installed when you come down.
Thanks,
Ben
We use delimit chip instead , does that reporgram only on that little chip ? If so, we can send it to tunner & keep driving the car.
List our delimit test for reference
Stock everything : 257 km/hr on speedo
Delimit : 298 km/hr on speedo by 265/35-18 tires(R)
Calibrate the tire size, ....... 305 km/hr
Thanks. Wavy lines is knock sensor reducing and bringing back ignition timing.
