Enginelight lit after pulleychange! C32 AMG
Mercedes C32 AMG
Hi everyone, i have fitted my 181pulley from EC, after driving a while and flooring the pedal in 60mph, when i reached 110mph the engineligt lit up!
Anyone have any idea what might heappend?
Thanks everyone!
Thanks everyone!
Probably an overboost CEL, but you really need to get a code reader and check out what code was thrown.
Sometimes they'll do it at a local Kragen for free. Or go to your mechanic and have them pull the code.
2008 A8L, 2002 996TT X50, 2009 X5
One can also buy a cheap code reader for ~50 bucks or less; check Amazon and/or ebay. A worthwhile addition to any enthusiast's toolkit.
Could be overboost, although I don't think that happened as frequently with M112K's running the 181 kits... mainly the 185's. Could perhaps be a misfire if any of his coilpacks are going bad... but, as you mention, the CEL code will provide the answer.
Now, FWIW, my C3 SC pulley (non- stacked stock crank pulley) has never thrown a CEL. One other thing, how about your octane? What are you running??
C32, 911 SC
I ran my 185 for a week without a tune, making sure that I didn't go over 4500 RPM and never get a CEL. I then had it tuned by Jerry and went WOT to 130 mph (in another country of course) also without any CEL. So, I would assume that you should be safe with 181 crank and not stacked.
Like others have suggested, but go to your local Autozone and have it checked. Good luck!
Mercedes C32 AMG
Thanks all for the answers!
I going to check the CEL today , the weather was rainy and an temperature of +5Celsius.
i will let you know what caused it later!
03 g35 coupe...........02 c32 Sold
yeah in cold weather the air should be dense enough to create overboost cels. I use to get over boost cels all the time if i went WOT at 60degree weather.
Mercedes C32 AMG
The CEL was infact the "MAP Sensor" i heard that is an common problem with tuned c32s?
The CEL have dissapeared when i started the car today but it came back some hours later and it was then i have the code read.!
Do i need to replace the map sensor or what do you guys think?
Thanks!
Thanks!
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
Thanks!
Thanks!
