Check engine light just came on...
Old Oct 14, 2010 | 09:23 PM
c32kompressor's Avatar
CLK55 AMG
i get a little soot after a few hundred miles, after i clean it, could i be running rich?
Old Oct 14, 2010 | 09:25 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
you tuned?
sounds a little rich.....
Old Oct 14, 2010 | 09:27 PM
loudandheard's Avatar
C32/C55 AMG
I get soot as well, but I'm not tuned. I think it's a common thing on c32's, but I could be wrong.
I had a similar issue with my check engine light, but it was for my secondary cats. Apparently my O2 sensor after the cats were going bad. The way they could tell was by checking the voltage of the O2 sensors and they would not respond at all some times. Check both your cats and if it's not your cats, then more than likely it's your O2 sensors.
Old Oct 14, 2010 | 09:28 PM
CLK55 AMG
Originally Posted by loungn14
you tuned?
No, I will be though in a few weeks hopefully, I want to go with your Jerry tune
Old Oct 14, 2010 | 09:37 PM
loungn14's Avatar
SPONSOR
ya, stock you run rich by default...your fine....
Old Oct 14, 2010 | 09:45 PM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
check that checked asap...could be bad plug or injector..
ecu will overcompensate and push more fuel if possible, but with no exhaust mods you should not get that error...
soot is indeed rich.....but I worry that it is caused by a deeper issue.
When I was stock I removed the charcoals and the same code got on. Put them back on and light never came back. Now I have the tune same code wtf?
Old Oct 14, 2010 | 09:49 PM
  #32
loungn14's Avatar
SPONSOR
all the more reason to be worried about a hardware issue. Could be simple, but DEFINATELY not something to ignore.
Old Oct 15, 2010 | 02:29 AM
  #33
SteveoAMG's Avatar
From: Manhattan upper eastide, New York City moved back to south florida currently
MooseJaws 04 C32
my cell just came on but im scanning it tomorrow to see whats up
Old Oct 15, 2010 | 07:36 PM
  #34
I have the obd2 reader and eraser. I just erase it but it comes back after few hundred miles. Talked to my good MB mechanic he is going to hook it up to the laptop. Hopefully pinpoint the problem.
Old Oct 15, 2010 | 09:19 PM
  #35
loungn14's Avatar
SPONSOR
I hate to sound like a %# here man, but please do not ignore that error. It could be something simple (fingers crossed) or it could be something that causes you to lose the engine.
If he has MB star your on the right path, let us know what he finds out, and if you need help let me know.
Steveo post up what you have when you get it scanned...
Old Oct 16, 2010 | 07:33 PM
  #36
Update on the CEL which is just an annoyance. Coming from tuner. There will be a delete for that soon.
Old Oct 18, 2010 | 10:27 AM
  #37
propain's Avatar
See Sig
Its probably just the purge valve. You have an 09 right?
Old Oct 18, 2010 | 08:13 PM
  #38
Yes a 09 but wouldnt the code read-purge valve?
Old Oct 18, 2010 | 08:18 PM
  #39
Update- drove almost 200miles yesterday. No CEL.
Old Oct 19, 2010 | 06:48 PM
  #40
propain's Avatar
See Sig
Mine stuck, thew the cell and then got "unstuck" and cell went off and didnt code.
The shop knew the purge valve was a common problem on the 09 and changed it.
1K posts! Woot!
