Don't Make Fun of Me...
Old Nov 18, 2010 | 02:17 PM
97W202's Avatar
2006 C230 6speed/14 C63
Tho I answered I cant seem to understand whats so hard about identifying a washer nozzle, the same goes for a brake caliper..
what information are u looking for?
Old Nov 18, 2010 | 02:57 PM
Newzchspy's Avatar
PLAID
Originally Posted by gruf
everyone seems to no so much here,
i asked a question about identifying brake calipers and didn't get one response,
someone asks about a headlight washer and your beating each other up to answer it,
i even read one answer and 2-3 hours later someone posted the same answer on the next line down but the only difference was the words were put in a different order.
i used to post on an Audi forum with some tricky question and you would always get an answer even if it weren't the one you wanted, was this question asked for a laugh.
there's a button to wash you headlights, if it don't spray water out when you push it then you need to check the obvious things first like this fella (amdeutsch) said.
i thought the forum was to help.
Why so Gruf???
Now, what was YOUR question???
Old Nov 18, 2010 | 03:00 PM
gruf's Avatar
c32 AMG
i have two rear, 4 piston amg calipers and one front 6 piston,
i need to make sure they are from a slk55 2006, also i need to get a second for the front so i need to make sure i get the match for the front i all ready have.
this is the only number on the front caliper 206885041a, i will post picturs tomorrow.
Old Nov 19, 2010 | 04:30 PM
gruf's Avatar
c32 AMG
ive posted pictures and my problem here
https://mbworld.org/forums/c32-amg-c...callipers.html
if you can help.
Old Nov 19, 2010 | 04:44 PM
moosejaw's Avatar
none
if you can help.
Wasn't this thread about headlight nozzles?
We're not as intelligent as your Audi freinds.
Your question is better off being asked at the desk of Stealership than here only because a lot of ppl having not done this upgrade.
Old Nov 19, 2010 | 04:57 PM
gruf's Avatar
c32 AMG
stealer's only sell parts with numbers and chassis numbers, if you show them parts without part numbers they sort of steam from the ears and a vain in there neck frobs.
im sure someone will come up with the goods.
Old Nov 19, 2010 | 05:19 PM
  #32
moosejaw's Avatar
none
I read your post and cant come up with no solution for you,
When you peicemeal this stuff together, you are going to hit roadblocks.
Dont buy anything used for these cars unless you know exactly where they came from.
Also try to keep your posts relative to the subject at hand.
People werent ignoring you, they just dont have a solution. Look up a guy named Harry Madan. He has a similar setup but he bought his. He may have the relative part numbers
There are some stealers that will help you. You only went to one i assume.
Old Nov 19, 2010 | 05:37 PM
  #33
gruf's Avatar
c32 AMG
ive got a stealer that will help and gives me trade, i have an old r107 sl500 i have restored and they no me well, i can get the other caliper but i just wanted to see if anyone could tell me if i had the right one.
someone said something about rotor size, is there a way i can measure this one i have here so i can order the right size rotors and the other matching caliper.
Old Nov 22, 2010 | 04:31 PM
  #34
pointman's Avatar
a car that can't do the throttle reset.
Old Nov 22, 2010 | 04:33 PM
  #35
pointman's Avatar
"vein".
You're welcome. MBWorld is here to help. I hope that put you in a better mood.
Old Nov 22, 2010 | 07:02 PM
  #36
Newzchspy's Avatar
PLAID
Breaks :)
[QUOTE=pointman;4364776]"vein".
You're so "vein" says Carly Simon, Or is it "vain"
Old Nov 22, 2010 | 10:38 PM
  #37
moosejaw's Avatar
none
Whose effin thread is this?
Capn Crunch or Gruf's?
