Flickering xenon headlights
the car only has 35k on it and those xenon bulbs are supossed to last just about forever correct? If it is just a sign they need to be replaced can anyone recommend a place to purchase replacement bulbs for less than the 180.00 a pop the dealership charges?thanks in advance
Moe
35K miles does sound a little soon for them to go out though.
Buy the Philips D2S bulbs or go to the dealer and cough up the $$$
I hat putting those in, they are such a PITA to install.
You can also get aftermarket bulbs which offer a different temperature range (they are all over ebay) but they will burn out in 10-20 K miles
Mine where doing the same thing with the flickering, it seems to get worse when its cold, under 75 degrees.
Eventually I got a "low beam" bulb error on the dashboard and the light stayed off, I turned lights off then on again and has been working fine ever since.
