OEM Benz wheels that fit the C32
Old Nov 29, 2010 | 09:46 PM
pealei392's Avatar
Question OEM Benz wheels that fit the C32
I just got into a C32 and it has c230 wheels on it. I'm interested in changing them. I would like to stay with OEM Benz wheels that bolt on (correct bolt pattern/offset) with NO modications (spacers etc). I've been searching the forums and have some ideas, but would aperciate additional input. Thanks in advance!
Old Nov 29, 2010 | 10:01 PM
moosejaw's Avatar
none
Would you be open to Forgestars F14's? They are pretty reasonable priced and i think they are custom made to your specifications
Old Nov 29, 2010 | 10:03 PM
AMGC's Avatar
Mosselman 190E 16V+ C63S+ Abarth 595
basically any rims that will clear the calipers will fit. All Mercedes have the same lug pattern. Any AMG rims will "fit". When you find a set your interested in, its more about what tires you need to run considering the offset of them.
Old Nov 29, 2010 | 10:11 PM
pealei392's Avatar
The F14s look pretty good. Definitly a possibility. Do SLK55 and or C55 wheels bolt on?
Old Nov 29, 2010 | 10:25 PM
PC Valkyrie's Avatar
C55 AMG, 135i, 911 GT3, GLE43 AMG
To answer your question, OEM AMG rims from the C55, CLK55, CLK63, and SLK55 should bolt on with no need for spacers or any worry about clearing brakes or rubbing or need to change lug bolts.
Even non-AMG OEM Benz rims designed for the W203 C-class, W209 CLK-class, and R171 SLK-class should fit with no need for spacers, as long as they are at least 17" diameter. Smaller rims will not clear the front brake calipers. But be careful, as there are some 17" rims which will not clear the front brake calipers, so you have to check.
For example, I have OEM 18" Style VI AMG rims from the CLK63 as my summer street wheels, and I have OEM 17" "Celaeno" rims designed for the standard W203 C-class as my winter rims.
Old Nov 29, 2010 | 10:48 PM
pealei392's Avatar
Exactly what I was looking for! Thank you sir!
Old Nov 30, 2010 | 12:17 AM
dontbanme's Avatar
C32
I have a set of stock OEM C32 AMG wheels with new tires that I may sell if you are interested. PM me.
Old Nov 30, 2010 | 02:49 AM
Gramma_Benz's Avatar
2002 C32, 2012 S550
You might try Gene Gorman if you want a perfect set of OEM C32 wheels. I thought they were kinda pricey, but they look in great shape.
https://mbworld.org/forums/wheels-tires/361338-fs-split-spoke-c32-amg-wheels.html
Old Nov 30, 2010 | 01:09 PM
Dingleberry's Avatar
Marsaydees
$1300 for stock wheels is the biggest ripoff i have ever seen in my life
Old Nov 30, 2010 | 06:17 PM
dontbanme's Avatar
C32
$1300 for the ole stockers??? Forget that! With that in mind I will cut someone a great deal on mine
Old Nov 30, 2010 | 06:24 PM
MIKESV8's Avatar
Aston Martin V8 Vantage
+1 deal with this guy.
Old Mar 7, 2011 | 07:27 PM
kingfish405's Avatar
97 318i | 03 C32 | 02 SLK320-6spd
bump for my first post!
can somebody please verify that a 2007 c230 17" 6 spoke rim fits a c32? i read that someone here tried it and it didn't fit. either he got a replica or it just doesnt fit.
thanks!
Old Mar 8, 2011 | 10:11 AM
Gene Gorman's Avatar
05 SL55, 10 C63, 12 SLK3, 20 S560, 08Bentley GT Speed, 16 Aston Martin Vanquish
Here is our C32 with SLK55 wheels.
Old Mar 9, 2011 | 05:45 PM
Piraya33's Avatar
2004 C32 AMG
Magma, could you PM me a pic of the wheels that are currently on your car if you want to get rid of them? Thanks!
Old Mar 9, 2011 | 08:58 PM
^ since nobody seems to have an idea about my question.. ill just answer it for peoples who want to change their stock 17" amg rims that look like 15" cause of the squarish design..
the rims i got were from the sport 2007 c230.. offset is 36 front and 34 rear.. 7.5, 8.5 wide..
they FIT and clear my calipers.. now my rims look like 17s. i could swear my 17" m-contours look a lot bigger than the stock 17" amg twin spoke.
my C32 now looks like a slow car.
