help.....
Old Jan 1, 2011 | 12:42 PM
trbo2nr's Avatar
2004 C32, 2006 Honda CBR1000RR, 2007 Harley NightRod, 2013 Harley Road Glide Custom
help.....
My 2004 c32 left me on the side of the road. I cannot get the closest MB dealer to pickup...maybe closed. I have my scan tool with me and limited tools. I am getting three codes. P0300, P0301, and P0303. Can anyone look em up? My cell phone is limited. Thanks a bunch! Yeah, I am on the side of the road in Charlottesville, Va.
Old Jan 1, 2011 | 12:48 PM
trbo2nr's Avatar
random misfire. cylinder 1 and 3 misfire. catalytic converter..someone
M
Misfire in cylinder 1 and 3 I am told or catalytic converter. How to fix that?
Old Jan 1, 2011 | 12:58 PM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
Can you scan tool clear CEL codes? if it can, clear it and start the car again. Worm up it and see if it goes again.
Old Jan 1, 2011 | 01:35 PM
trbo2nr's Avatar
yes I did that and was able to get a few miles then it started giving the CEL again. I called roadside assistance and they cannot locate me even after giving my location from the navigation... Gonna be a long day.
Old Jan 1, 2011 | 01:44 PM
Lenin's Avatar
When was the last time you got gas? Was it from the usual place?
Old Jan 1, 2011 | 01:58 PM
trbo2nr's Avatar
Same place as i always use. I just drove 80 miles and the car was fine. Then I visited a buddy for like an hour, got in the car and drove for a few minutes before the CEL came on.
Old Jan 1, 2011 | 02:25 PM
boohooramblers's Avatar
Not an AMG :(
1. Is your car modified +/- tuned? If so, list your mods (possibility of running a low AFR and subsequent fouling of cats, etc.).
2. Related to the above, are you running aftermarket air filters such as Green filters? Check for the possibility of oil or otherwise messing up your MAP sensor.
3. Do you hear any rattling from the catalytic converter areas? (possibility of bad cats).
4. Have you checked all plugs and wires to and from the coil packs?
Old Jan 1, 2011 | 02:37 PM
trbo2nr's Avatar
I do have green filters and modified for a number of years now. No rattling and all stock parts are at home. It feels like coil packs or something is bad but not the MAF. Feels a little different than the MAF. Calling a taxi and found a home to leave the car at until Monday as everything is closed. All looks tight under the hood and the previous 80 miles I drove were fine. The problem surfaced after I turned the car off for an hour and started back to head back home.
Old Jan 1, 2011 | 03:03 PM
JUAN CASAUS's Avatar
2005 E55 AMG
When I got those codes with my C230 it was a bad ignition coil
Old Jan 1, 2011 | 03:05 PM
2005 E55 AMG
Could be O2 sensor too.
Old Jan 1, 2011 | 03:47 PM
trbo2nr's Avatar
Thanks everyone. How much for either of those jobs?
I am in the comfort of a hotel room and reduced rate until Monday....everything is closed....
Bob
Old Jan 1, 2011 | 05:37 PM
2005 E55 AMG
Either one is an easy diy...is just a couple of bolts and the plug wires but you'll have to take the filter housing off.
Old Jan 1, 2011 | 06:58 PM
trbo2nr's Avatar
I am heading to the local auto parts place in the morning by taxi......and looking for the Bosch replacement parts. I can't imagine two ignition coils could have gone out but thinking a common part. Car ran fine for the 80 mile trip but once it cooled off and restarted, that's when the problem started. I once heard a mechanic say the scanners just tell the symptom ( in my case the P0300, P0301, and P0303) and thinking if the O2 sensor is really the fault? How long do the O2 sensors last.
Old Jan 1, 2011 | 08:12 PM
2005 E55 AMG
Depends...if you're running rich they'll go out quicker.
Old Jan 1, 2011 | 08:22 PM
trbo2nr's Avatar
Oh ok. thanks.
Old Jan 1, 2011 | 09:34 PM
thtguy's Avatar
2017 GLS 550
too bad I moved from C'ville to Tampa 1 1/2 years ago, I coulda been available to help you out.
Best of luck on repairs.
Old Jan 2, 2011 | 03:32 AM
MIKESV8's Avatar
Aston Martin V8 Vantage
this really sucks. i can't believe the car just died without warning........... happy new years buddy!!
Old Jan 9, 2011 | 05:33 PM
trbo2nr's Avatar
Turns out replacing the plugs and wires did the trick.
