after market deck Install
I'm being told that the AMG cars have an optical connector on the factory deck and a standard wiring harness would not suffice. This would require them to rewire the entire system and could cost around $450 - $600 in labour.
Can someone here who has put a different deck in their C55 (mine's an 06) share some insight?
Do I go with futureshop and run the risk that they might not know what they're doing or go with the smaller company who seems like they know what they're doing, but might be trying to rip me off?
I want to change the deck because public radio here is the worst; I wanted a built in nav system, with ipod and satellite radio hookup. Not some aftermarket business on my dash (just looks too ghetto for a Benz imo)
I purchased a swi can2 and swi jack from pac audio as the dealer at futureshop suggested I do so. I'm confused about relocating the factory stereo. Are you talking about the deck? I have to leave it in the car?
Why would you suggest I change the factory speakers? I'm happy with the sound, is there another reason they should be changed? Will they not work with the new deck? Further, can I not just use the factory sub as well?
Is the stock deck providing amplified power to all the speakers that the new deck I want put in won't provide? Is this the reason I need an after market amp? If there is already an amp in the car giving power to my speakers, can I not just use that same amp?
Sorry about all these questions, I just wanna make sure I know what is going on before I hand my keys over to the installers.
Thanks!
Thanks!
another reason why you need to change your speakers if you put an aftermarket amplifier is because your factory speakers are made to run at 2ohm and an aftermarket amps puts out 4ohms so you would have to keep the amp gain all the way down otherwise more distortion would come. you need to use the can 2 system otherwise you would need to relocate your factory stereo. hope this helped
